[size=small]Impressions…..[/size]
[size=small]Well I was not really there to run around and listen to everyone’s systems. I was one a mission (in some ways). [/size]
[size=small]L3000 hunt: After many got to play with the leatherheads, I took them around and plugged them into most major amps in the place with my CD in hand. The greatest sound…. Well it was of course the monster Frank amp that we can’t own…. The GM70’s and the blue glowing tubes created a soundstage and depth of music and tone that was unrivaled in my ear. But the others that had a lot of fun with were the Guzz - Single Power Extreme Platinum, and the Eddie Current Balancing Act. If I were pushed for one I would pick the EC. The SP had lots of slam and impact. But the Balancing Act has more options and the sound was a little more neutral and detailed. [/size]
[size=small]The HD2 and ZD did not seem to have the control over the L3000 that I would look for. Al’s Monster SDS just didn’t have the right tube set. It sounded off. I know that it could push the L3000’s, but it was not setup for them that day. [/size]
[size=small]Electro research: I was able to listen to the O2mk1 (mine), O2mk2, 4070, HE60, HE90, he1.2 all out of my ES-1…. So it was a pretty good run. [/size]
[size=small]Mk2 vs. Mk1. They are slightly different, but I don’t think that the Mk2 was broke in at this point. I had a simple question to ask. Do I need to replace my MK1 for the MK2?? … Nope. There are some slight differences, but I don’t see it as an upgrade path, just the new release in the series. If I was buying today, I would get the Mk2’s, but since I have the Mk1’s… I am happy.[/size]
[size=small]4070…. I liked them for what they were, an enclosed very forward Electrostatic. High level of detail was all there. They had a larger Bass impact than the standard O2. Another question to answer, Do I need these? Maybe… If I didn’t come across the 1.2, I might have them on order at this point. Future will tell…. Anyone selling one?[/size]
[size=small]HE60 and the he1.2. I really liked the first listen to the 1.2. So much so that I have ordered a pair. Going back and forth with them and the he60. I liked the 1.2’s better every time I put them on. The soundstage, tone and detail seemed to be all there in spades with the 1.2’s. Will the 1.2’s become my new standard? I am not sure. The O2’s are so good, that I don’t see them going anywhere. Long term listening will tell the tale. [/size]
[size=small]He90… they sound good…[/size]
[size=small]More later…… [/size]
[size=small]Cheers,[/size]
