TheBigCW
- Oct 29, 2009
If you're getting a hum it's almost definitely because of the fact you're using very sensitive phones with a very high gain amplifier.
Originally Posted by JustVisit /img/forum/go_quote.gif Technically, there shouldn't be hum sound since the amp stage is shutdown when there is no audio signal feed. I still suspect it has something to do with the power or grounding. |
Originally Posted by thearrow /img/forum/go_quote.gif Would there be some way to easily replace a few wires that run to the headphone amp with shielded ones? I'd still want to upgrade my phones, though. Anyone have any suggestions that would pair well with the super-high-gain headphone amp on the mav? |
Originally Posted by thearrow /img/forum/go_quote.gif So you've tried your k601s (120 ohm?) out of the headphone amp and don't get any hum? |
Originally Posted by thearrow /img/forum/go_quote.gif EDIT: Also, BigCW, I'm curious as to how you'll like the windmill getters, so when you roll one in please let me know what you think of it. |
Originally Posted by TC44 /img/forum/go_quote.gif I'm interested in using one of these to replace my current Adcom GTP 500 preamplifier. I've read through the 28 pages and didn't see very much on how this performs as a preamp. I have a pair of Beyer DT880 and the D1 sounds like a good match, but I'll also be looking to replace the Adcom preamp. Anyone use this in place of their preamplifier? What do you think? Thanks! |
Originally Posted by ELP FAN /img/forum/go_quote.gif One thing id do think needs addressing is the black brush anodised facia, it's too shiney (gives a patchy cheap effect) in needs to be more matt it will look very high end & more expensive looking to boot. It's a great thing & i will be buying another one or two if a more matt finish is employed as i want it with my hi-fi but not prepared to do with the shiney finish, so this one stuck on my computer. |
Originally Posted by sp70 /img/forum/go_quote.gif Some of the lettering on my unit is actually starting to scrape away from simple everyday use. Its not enough to bother, but it does give the impression that its a bit more cheap looking. I treat my gear very nicely, and its disappointing that the lettering paint is starting to rub off considering its age. |
