middachten
- Jun 28, 2010
I've listened to a lot of music this weekend
And also to a lot of equipment combinations. I've tried to check out how the D1 behaves when connected to its various inputs. And I've done some listening test to compare it once more with my TC-electroncs Konnekt D24. The D1 is equipped with an OP249 OpAmp in the line/DAC stage. I've used the regular (non tube) output. The connections to the poweramp (a Duson A10) are made with Straightwire Rhapsody and the EPOS M22i speakers are connected with Nordost Blue Heaven cables.
I've used the following connections:
#1 source: Macbook Pro using VLC
- USB > D1 > Power Amp
- FW > D24 > SPDIF > D1 > Power Amp
- FW > D24 > Analog D1 > Power Amp
- FW > D24 > Power Amp
#2 source: Philips NP2900
- SPDIF out > D1 > Power Amp
- Analoug out > D1 > Power Amp
This is a picture of the setup:
![](https://www.head-fi.org/attachments/57333/)
BTW the Preamp was not used.
I've listened to a lot of music, but the comparisons where made with these two recordings:
- Crowded House - Woodface (track 7 & 10)
- Leinsdorf Sessions / Strawinsky Firebirs suite (part 4) - on Sheffield Lab
Both recordings where played using original CD's ripped to FLAC with EAC.
My conclusions:
From this experiment I conclude that the D1 is susceptible to the quality of the SPDIF feed. In fact, in some cases the USB connection might give better results!
Some side conclusions:
- The NP2900 is nice as a network player, but not such a good feed for the D1
- The TC-Konnekt is a good quality audio interface, that could benefit from better electronics in the analog output stage. Its a shame that its much harder to do OpAmp rolling in this unit than with the D1!
![atsmile.gif](http://files.head-fi.org/images/smilies/atsmile.gif)
My conclusions:
- The best connection was trough SPDIF, using the D24. This setup resulted in the best soundstage, most extended and controlled bass response and an overall smooth tonal response while maintaining dynamic feel. The D24 is know for its good jitter behaviour. It uses the custom designed DICE-II chip from TC. And te SPDIF output uses quality transformers. Hence I think that the D1 is served with the best possible (low-jitter) SPDIF signal. Resulting in a lower dependence on the jitter rejection of the SPDIF receiver.
- The worst, while using the D1, was the SPDIF connection to the NP2900. Bass response was less extended and had a typical hump around 150Hz. The mid-high frequencies where more harsh. And, most importantly, the soundstage was much smaller and less deep and dynamics where duller.
- The direct analog connection of the NP2900, using the D1 as preamp was even worse. Flat, lifeless and shril.
- The D24 directly connected to the poweramp showed better soundstage, and significantly more detailed high freqeuncies. But at the cost of more shrill mids and highs. In terms of tonal balance the connection using the D1 as preamp sounded much better.
- The D1 connected trough the USB interface sounded better than the D1 connected to the NP2900, but not as good as the D1 connected to the SPDIF of the D24. There where remarkable similarities between those options though. The effects where in the same areas (bass extension/control, sound stage and dynamic feel. If the SPDIF/NP2900 was on one end of the scale and the SPDIF/D24 on the other end, the USB connection would be on 1/3 towards the latter one. In other words, not bad at all......
