Anyone else smelling another "Skyline" mod on the Tube Magic A1?
Here's what you need for the D1 mod v2.0:
-50x50 cm plate of plexiglass with 2mm thickness
-4 screws
-a Dremel or a clone of one
-patience, lot's of it, don't hurry this.
1. Here are the exact sizes for the faceplate and case sides: 25x16cm | 2 x 5x16cm. If you don't have the tools for a clean cut, you can go to a specialized store that cuts it for you according to the sizes. Do not take off the protection foil, because we don't want scratches in it yet.
2. Take off the old casing, since we won't need it anymore. Here's what you do next: Place the faceplate on top of the D1 and try to fit evenly on all sides, after that go ahead and drill holes into the plexiglass for the hex screws.
Don't ever overtighten the screws, this will make the plexiglass bend a little and has chances to break off stuff on the edges.
3. Everything fitting nicely? Great, but we're not done quite yet. The sides are a bit more complex, you need to drill holes into the case endings on each side and better be very careful with that, especially near the transformer. Make sure that the screws should move "smoothly" into the case and not loose, they won't be able to hold the sides otherwise.
4. Fitting sides and faceplate? Check. Ventilation holes? Nope. Guess what comes next. Generally speaking, bigger ventilation holes let more heat out than smaller ones, but also have the chance to gather much more dust. In my first version of the mod I used big holes and the D1 was only warm to the touch, the second version features much more holes stretched across the PCB, but are way smaller and don't really change the heat distribution. The transformer section doesn't even feel warm at all after 6 hours. If you don't use the tube at all, you're probably better off drilling in some holes over the big caps and OPAs.
5. Take off the protection foil, clean leftovers from the drilling, plug in your D1 and enjoy your "Skyline" mod. Not only does this mod transfer heat better, but it also allows you to use Audio-gd HDAMs in the headphone and DAC section.
Be very careful when drilling plexiglass at high speed, it gets very hot and melts. If there's enough interest, I'll also do custom orders for the lazy ones.
