liamstrain
Member of the Trade: The Audio Guild
- Sep 18, 2011
USB? Optical? or other line out?
What is the volume from the computer set at?
Some integrated amplifiers still use a resistor off the speaker output for the headphone jack. Your Yamaha AX-492 may be one. If so, it can drive a Hifiman HE-6 let a lone your 770. Then again the headphone amp of the Mini-i was advertised to be added bonus rather than a main feature. Just so happens that it sounds pretty good and some of us like the characteristics of that sound.
I see what you mean. But the if I recollect correctly, the Matrix is advertized to be able to drive cans with 300ohm imp. The Beyers are only 80ohm.
since i'm on the brink of checking out my matrix balanced order, i'm searching the net for possible 'no-go' signal...i found this thread in Jaben: http://jaben.net/forums/index.php?topic=16254.0do you need your souce - optical, coaxial, USB - to be balanced to have a fully balanced setup???what does balanced digital input mean then??
mini-i amp senn. hd600 feed?
does the amplifier of matrix mini-i dac support hd600?
