maii
- Sep 29, 2011
Hi I'm new with this DAC. I have purchased this DAC matrix mini I last week and plan to replace op amp with Burson discrete op amp.
I use this machine as a DAC only(headphone and pre are off) and I connected analog output with XLR to pre amp then to my Burson HA160D for headphone(I prefer Burson for HPA)
and Unison S2+Bugle boy amperex NL pre+ Mullard el34 xf1 fat brown base for loudspeaker(This section with sound out of the speaker with Matrix is much better than burson since Burson has its tube sound added to tube amp it's over the top of "sweetness(too much)" so Matrix is a very good match and it the reason I bought Matrix)
May I ask one question. If I use only DAC section will the output stage circuit is running out to analog XLR output like this
AD1995>OPA1234>XLR output
as I understand OPA275 is stop working when you set up the unit in DAC function. It's working only on Pre function.
Am I right. That I will only replace 2 x OPA2134 with Burson op amp to use for pure analog output.
Thank you in advance.
Best,
MAII
Best,
MAII
