If your Apache can't handle a 2 volt source then an XDA-1 might be a good matchup as it is only 1 volt like an iPod LOD. I have read great things about that DAC, if it will work in your setup it's a great value. But many high-end sources are 2.5 or even 5 or 10 volts, it has nothing to do with how "mid-level" the amp is or not. It's just about matching up the output voltage of the source with the input voltage that the amp wants. There is no right or wrong and it has nothing to do with quality, or even if the amp or source is balanced or not. Many sources have more voltage going out of the balanced output than their RCA outputs, but I think they are close to the same voltage out of the Mini-i. The Apache is an active preamp first and foremost, so it is ideal for low-voltage sources.
