AlfBaxter
- Aug 10, 2010
Definitely the OPA627, preferably in class-a. The first thing I noticed when I changed the stock opamp for the 627 was how much more spacious everything sounded, and more 3-D.
Originally Posted by Elar /img/forum/go_quote.gif
Thanks, I think I'll give them a try. I don't have any diy skills myself, but if I have the right components I may go to a audio shop or something and have them put it together. Any idea how much that will cost me and where to get those components here in Europe? A good price would be great, as buying HD650, V-Dac and M-Stage the last months has left me with no more money to spend for audio.
Should one turn off the Matrix when changing the gain settings?
But after changing the OPA to Earth last night, I tried the other settings and I think it sounds better at 20dB - more open and with better soundstage. I don't know if this is in my mind or if it makes sense hearing some difference in sound between those settings, if this is the case I think I'll have to rewrite the brief comparison I made some pages ago between LM4562 and OPA Earth.
I installing the OPA Earth a simple plug and play swap? If yes, where do you find this op amp?
Yes, but be careful with the little "half moon" mark there, ok?
I bought my Earth OPA from Audio-GD, you should mention the DUAL. Buy the extension lead too, 100mm, but ask if they can make an 110mm extension so it leave you a little more room.
One more comment about this OPA, my impression is that Matrix is running hotter than before (LM4562 2.7k)!
