Sure buddy. =p
Matrix M-Stage amp review: simple, cheap, and excellent.
kongmw
- Jun 2, 2008
This suggestion by purrin "seems" to have fixed my amp for now.
I really tightened the screw, powered up the amp with stock opamp and with no source whatsoever, and heard NO hum whatsoever. Delighted by this, I proceded to install the 627 opamp and test again. The amp once again produced no ground feed hum, so I tested it connected to my dac, and I'm using it right now, happy as a little panda over the fact that the amp no longer produces any unwanted noise. Once again, it just delivers fantastic sound to my Denons.
I won't know for sure if the problem is permanently fixed, but I gotto say, things are looking very good.
I would like to thank every one of you that has contributed, and also to tamsaudio from whom I've recieved mails from regarding this. Top service!
Thanks everyone! Music awaits
I just got my m-stage today and same problem here. humming/buzzing at all gain settings with or without anything connected to it. I haven't yet tried connecting iPod to it yet but did swap a couple sets of cables. But again, humming/buzzing exists regardless of whether anything is connected to it. It comes as soon as the amp is turned on. I will try messing with the hex screw tomorrow, even though that means I'll have to lug it to school. Fingers crossed. I would hate to send it back to China...
kongmw
- Jun 2, 2008
wow okay, fixed my own problem by tightening that screw from the bottom of the amp. should'a tried that first before posting...
- Aug 2, 2008
^ Heh, loose transformers... or other minor issues.
LOL, coolfungadget should be give me a discount, gift certificate, or something for being his unofficial technical support and Class-A op-amp mod champion.
jtam
Member of the Trade: Tam's Audio (coolfungadget)
- Apr 27, 2009
Feel free to ask when you want to purchase anything...but, I am not the only one selling Matrix stuff. Make sure only support my customers, -____-
Jibbie
- Sep 3, 2010
Haha I love how manufacturers post in these forums. Allows for entertaining exchanges like this one
mmayer167
- Mar 7, 2007
^ ditto, lol
- Aug 2, 2008
LOL, I'll take you up on your offer one day. And I'll make sure to ask if they are a customer of yours.
Hi all,
Just picked up an M-stage in the market and sounds great with my K702s. The only weird thing is this: it seems as if the RCA jack inputs are reversed on my unit. The left jack is pumping out the right side, and right jack is pumping out the left side. Just wondering has anyone encountered this issue with the M-stage? I’ve tried both source inputs on the Matrix and the same thing on both. I also confirmed my source CD player by using 3 separate RCA cables, triple checking that the left output was indeed going to the left jack input, and the right output going to the right jack input. I also tested an older CD player as well just to double check another source, with the same result.
Anyone have any ideas what could be causing this? My only solution is to reverse the jacks, my source right output going into m-stage left, and source left output going to the m-stage right. This works fine, but seems a little bit unsettling.
jeff119
- Nov 30, 2009
i have the same problem on my m stage ever since i got it... I doubt it is something serious.
Hi all,
BmWr75
- Jun 20, 2008
Yep, the jacks are wired up in reverse inside the amp.
Wow. Interesting. Puts my mind at ease. Thanks guys.
VanCitySound
- Feb 28, 2011
That sucks.
Zafonic
- Aug 4, 2008
Has anyone used the M-Stage with the Matrix Mini-i? Would they make a good combination since from what I've read the Mini-i has a more tube-like sound while the M-Stage is more detailed.
Or is there a better amp that would blend with the Mini-i? Headphones would be Sennheiser HD 600.
Thanks
Thanks
Dubwisee57
- Apr 28, 2011
That sucks.
This is really strange that nobody point this out earlier.
