Wondering if you can share more listening impressions comparing the matrix to the Gungnir. I also have Gungnir and previously owned a sabre 9018 dac that I enjoyed but felt sometimes sounded too HIFI (too much treble, a bit fake sounding) but other reviews on the 9038pro say it sounds different to the older designs.
Hi Arnold,
Sure, I am happy to share my thoughts about this DAC but forgive me if I make some writing mistakes as english is not my first language.
First I need to tell you that I don't have the Gungnir with me for a direct comparison, I am currently living as an expatriate and my Gungnir stayed in my country of origin with the preamp and most of my heavy HIFI system. Basically that's why I wanted a "all in one" solution (I didn't want to have a separate system to save some space and limit the amount of cables).
Also i may be a little biased as I don't have any problem listening to the two SABRE32 ES9018K2M chips from my Opus #2 DAP for extended listening sessions. I think that while every chip may be different, the integration is critical.
I was able to spend some time listening to the Element X this weekend and I made some interesting findings...
Playing music through the MAP (Matrix Audio Player) with the hard drive directly connected to the DAC does sounds much better than via the computer USB input!!!
That's how I was playing most of my music so far so I didn't notice the difference at first but after this weekend I can confidently say it. I am happy with this finding because I wanted to be able to use my macbook running on it's native system while listening to some music (if I play music via the macbook I need to run Windows 10 to play DSD natively since this format is not handled natively by Mac OS).
The problem is that on some songs the difference between the MAP and the PC to USB input is probably too great to be normal... I will not comment more on it right now as I may have done something wrong with my settings. I will just say that I have already contacted Matrix Audio Support to see if we can find a solution. It is the weekend now so they will probably come back to me early this week (by the way I exchanged a few emails with them prior to the purchase and they are very professional and responsive, very dedicated team).
Now playing music via the MAP with my SSD hard drive plugged direclty into the DAC is just amazing, I repeat what I have said before, that's the best souding DAC I had the opportunity to hear.
The sound is just right, not too bright, not too forward, it doesn't sound fake, there is a lot of space between each instruments, voices are super realistic...It is definitely a very revealing and high resolution DAC, you hear lot of details that where just not here before. I listen to a wide variety of music from rock, soul, jazz, reggae, pop, electro, opera and the effect was the same with all of them, the music is right, simply what it is supposed to be. This DAC is "colorless" in a right way without being boring. I had experiences with boring HIFI components in the past (I had boring preamplifiers and even amplifiers but never a DAC). The voices are soooo good and for me who is listening to a lot of english songs, being able to hear all the lyrics clearly is just so satisfying. Of course what is true for the voices is true for the rest of the music.
An other point I have to highlight is the integration of the volume controller. It is pure wizardry!
I recently had very disapointing results with one of the most highly regarded passive preamp available (from a company that I will not mention here because I don't want to shame anyone) so I was more than skeptical of the volume control of the Element X being a mix of passive and digital control... My fears have completely vanished!! The volume control is excellent, with headphones or speakers, I don't hear any loss of quality or dynamics playing at low level (lack of dynamics is the usual problem of passive preamps, even with carefull impedance matching, there might be some exceptions like transformer volume controls but I've never heard one), Element X volume control is very responsive and accurate, perfect for my personal use. You can also control the volume when playing Native DSD (some DAC are not allowing that). So very good news on that side, no need for a preamp!
This DAC is trully an "all in one" wonder!
So far I would say that it would have been a perfect purchase for me if I was not having the issue using the PC to USB DAC input, but since my plan was to use it without PC from the beginning, I am still very happy and very impressed by this unit. Also I am hoping to solve the current problem with Matrix Support Team.
Now comparing the Element X to the Gungnir, I would say that the Gungnir is a very analog, pleasantly sounding DAC. I was using (and will use it) as a DAC connected to the coaxial output of my Sony SCD-555ES player (the real SACD player, not the 5 discs changer) and it sounded very good and vinyl-like in a good way. My problem with it in my current situation is that it doesn't have a headphone amp, it requires a preamp to control the volume (I was using a "vintage" Classé Audio Six preamp with the Gungnir with very good results), it needs a PC to feed the data and it doesn't play DSD files. DSD files recently became more widely available and with the proper gear, native DSD files are definitely better than 16 or 24 bits recordings (I don't do upsampling so I cannot comment on that).
The Element X fulfills all these requirements and more. It may sound less colored than other DAC for some, but it is definitely ultra revealing and it sounds very real in my system with plenty of space between the instruments. If you play mostly CD "red book" files and you like the Gungnir, then just keep it and enjoy the music! And if you have the opportunity to hear the Element X in the future, you may decide to buy it if you like it. But if you want to have a "all in one" solution that can reveal every musical details and play all types of high resolution audio formats, then the Element X is probably the way to go (I would recommend it wholeheartedly only if I can fix the problem described above).
