- Mar 7, 2007
I see, thank youIt's a cable brand that cannot be spoken of here ...
https://www.aliexpress.com/item/400...exp_id=3c0036f7-3bda-481d-9de5-eb7c7e7c11d6-2
Thank you @Tomm11It's a cable brand that cannot be spoken of here ...
In my experience, any of the cables with gold plating seem to increase bass and warmth. I would recommend something like the tri cable or any gold mix.
This is the tri cable. Just fyi its stiffer and thicker than the other 8 core cables. Softest 8 core and most flexible I've tried is the graphene but its heavier.
https://www.aliexpress.com/item/100....store_pc_groupList.8148356.15.3db42ca2w84UIF
There are definitely differences between the cheaper copper/silver and the more expensive. Main differences are quality of metal used, quality of solder, and quality of connectors.So far that’s my second favorite cable and I use a matching c to c cable currently. IMHO this one sounds a tad better to me.
https://www.aliexpress.com/item/100....store_pc_groupList.8148356.37.1f994cbbaS1yO1
I do have a new solid silver cord that was a special order and has more cores than the one he list. Heard mix things on silver so wanted to try one out. He did offer it with Graphene but was twice the cost.
Heard mix things on Graphene cables so decided to research it more. Any thoughts on what Graphene does or doesn’t adds would be helpful. Love XINHS work but iffy on quality that a cheaper Graphene cable will add. Seems to be expensive to make high quality Graphene and at the price seems to good to be true?
I have two graphene cables.So far that’s my second favorite cable and I use a matching c to c cable currently. IMHO this one sounds a tad better to me.
From what I've noticed from testing it doesn't matter cause all the silver cables tested I've seen have a lot higher resistance than the copper and spc cables we have, even the cheap ones. My hypothesis is it's the thickness that makes a bigger difference in resistance. These cables aren't long enough for skin effect to be an issue, but if it is a thing having a litz cable, or spc would be superior to just copper but I have no idea if it matters any. I have around 10 cables that I'll be testing soon with multimeter soonish so I might be able to confirm a few things then. Theoretically a thick high purity graphene cable would be best but it's too expensive to produce a good one so most graphene cables aren't much better or actually worse (from what I've seen of other people's testing) than the cheap and thick high purity copper/spc cables we can get easily enough.I have two graphene cables.
As far as graphene itself, 14christ is correct, its even more conductive than silver BUT it's hard to say how much of an effect has in these cables. It could be just marketing Bs.
Because to make use of it's conductive properties, as I understand it from the articles I've read, needs to be bonded to other metals with extreme heat or chemically. Or maybe there's some other type of manufacturing process that's not common that they're using. The world's in the wild experimentation phase with graphene and everyone is keeping their cards close to their chest, so we don't really know.
With that being said, I prefer the sound of the graphene cable vs all my other cables. To me it sounds better.
The most gibberish in your comment is "high purity graphene cable". Graphene is a single layer of sp2 carbon, and the "bulk graphene" is well... surprise-surprise, old good graphite, a moderately conductive material, understandably not used for cables.From what I've noticed from testing it doesn't matter cause all the silver cables tested I've seen have a lot higher resistance than the copper and spc cables we have, even the cheap ones. My hypothesis is it's the thickness that makes a bigger difference in resistance. These cables aren't long enough for skin effect to be an issue, but if it is a thing having a litz cable, or spc would be superior to just copper but I have no idea if it matters any. I have around 10 cables that I'll be testing soon with multimeter soonish so I might be able to confirm a few things then. Theoretically a thick high purity graphene cable would be best but it's too expensive to produce a good one so most graphene cables aren't much better or actually worse (from what I've seen of other people's testing) than the cheap and thick high purity copper/spc cables we can get easily enough.
Don't take this for something more than what it is, its just a question. I'm asking this because I'd like to know.From what I've noticed from testing it doesn't matter cause all the silver cables tested I've seen have a lot higher resistance than the copper and spc cables we have, even the cheap ones. My hypothesis is it's the thickness that makes a bigger difference in resistance. These cables aren't long enough for skin effect to be an issue, but if it is a thing having a litz cable, or spc would be superior to just copper but I have no idea if it matters any. I have around 10 cables that I'll be testing soon with multimeter soonish so I might be able to confirm a few things then. Theoretically a thick high purity graphene cable would be best but it's too expensive to produce a good one so most graphene cables aren't much better or actually worse (from what I've seen of other people's testing) than the cheap and thick high purity copper/spc cables we can get easily enough.
It's not the graphene that would need to be high purity, but the copper in the alloy (or whatever it is, I've seen some marketed as alloys so that's what I'm using here). I haven't really looked into them too much cause the affordable ones don't even test well in resistance so I don't see why I would bother over a good old thick litz copper or spc cable. It's a lot less cost prohibitive to produce good quality copper or spc cables so it's hard to find any cables that are ACTUALLY more conductive, these "graphene" marketed cables included.The most gibberish in your comment is "high purity graphene cable". Graphene is a single layer of sp2 carbon, and the "bulk graphene" is well... surprise-surprise, old good graphite, a moderately conductive material, understandably not used for cables.
What is sold to gullible audiophiles as "graphene" cables is "graphene-coated" (sprinkled, infused, here is your good chance to stretch your marketing abilities) copper, a perfect demonstration how "name game" works to sell cables.
When science is ignored, the ignorance can be costly.
This has been tested already by some people. It depends on the iems. Some iems are more sensitive to the resistance/conductivity of the cable, which can make the sound warmer or brighter. I think it was BA iems being more sensitive to it, and single DD iems being pretty much unaffected?Don't take this for something more than what it is, its just a question. I'm asking this because I'd like to know.
If one cable measures .2 ohm and another .8 ohm, what does a difference in .2 or .5 or any ohm sound like? What does the measurement of ohms indicate in terms of sound?
You're saying an increase or decrease in .2 ohms will yield a warmer or brighter sound depending on the iem?It's not the graphene that would need to be high purity, but the copper in the alloy (or whatever it is, I've seen some marketed as alloys so that's what I'm using here). I haven't really looked into them too much cause the affordable ones don't even test well in resistance so I don't see why I would bother over a good old thick litz copper or spc cable. It's a lot less cost prohibitive to produce good quality copper or spc cables so it's hard to find any cables that are ACTUALLY more conductive, these "graphene" marketed cables included.
https://forum.hifiguides.com/t/which-200-300-iem-to-get/28676/235You're saying an increase or decrease in .2 ohms will yield a warmer or brighter sound depending on the iem?
Do you have a link to these tests? Or name of the people who conducted these tests?
Lol got it. I'm not saying he's wrong but no offense but thats far from definitive proof.
Compared to "believers" of all shades, he was always clearly saying that only resistance can matter for IEM cables, and he outlined the points how it matters and have a great database of cable resistance to guide people.Lol got it. I'm not saying he's wrong but no offense but thats far from definitive proof.
He doesn't believe cables change the sound in anyway. Has he suddenly changed his tune?
