Budgetconstraint
Thanks for sharing, other than using an Android phone versus the Iphone of yours, my requirements are basically similar to yours.Yes I have received it. I wanted a cable to go with my KZ BA10 and KZ ZS6 that was 1) nicer and less tangly than the stock cable 2) was black and 3) had an inline mic to use with my Macbook and iPhone.
It certainly is a nicer, black cable, although there was a pretty strong smokey smell on it. Here's a pic:
But the problem is that the mic doesn't work on my Macbook or iPhone (via the lightning dongle). The input volume barely registers.
I have a few KZ IEMs each with the inline mic on the stock cable and these all work perfectly. I wasn't happy with the feel of the stock cables, hence had been trying to find a decent replacement.
That brought me to this Nicehck Blackwheat cable, but also the Tripowin C8 and 2 budget cables on Aliexpress and none of these have a mic that works on Macbook, nor the Apple Lightning dongle.
I also have a few 3.5mm extension cables as well as a CTIA conversion cable but made no difference.
I haven't tested these on other devices like any other DAC or non-Apple device, so I can't speak to that.
So I basically gave up on this quest for a good cable + mic, there are just very few options available and I think I've tried the best looking ones. Let me know if you find any luck.
I was hoping to hear some good news from you on the Blackwheat cable.. lol... But it is what it is i guess...
I'm thinking of trying to get the similar black JCally cable w/mic but with a Type C connector, hopefully the mic works on my laptop.
