Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Apr 5, 2021 at 10:47 AM Post #5,956 of 9,225
Apr 5, 2021 at 11:07 AM Post #5,957 of 9,225
Any recommendations for a good MMCX cable with microphone?
I prefer ones with no memory wire, or curved ear loops. Need to upgrade Toneking Dendroaspis buds.
Also, I found these on ebay, but not too sure on the quality:
https://www.ebay.ph/itm/Upgrade-OFC...435256?hash=item3d7e16e738:g:lH4AAOSwTxhcJ1IW
https://www.ebay.ph/itm/Original-6N...460597?hash=item3d351345f5:g:-hIAAOSwFb5aF6ET
Thanks in advance!
I don't have either one but here are two:
NiceHCK Blackwheat https://www.aliexpress.com/item/1005001732242657.html
Tripowin C8 mic: https://www.aliexpress.com/item/33038475232.html
Apr 5, 2021 at 4:57 PM Post #5,960 of 9,225
These are the links to the ones I've found:
1. US $81.60 | Large 8 core Gold, silver and copper mixed wire MMCX 0.78mm 2 Pin QDC TFZ Diy Earphone:
https://a.aliexpress.com/_mKb7v7H
2. US $60.38 | IEM Gold, silver and copper mixed wire Audio Cable MMCX/0.78/TFZ/QDC Connector For Andromeda SE535 Headset:
https://a.aliexpress.com/_mOyHmU3
3. US $60.38 | Large Gold, silver and copper mixed wire MMCX 0.78mm 2 Pin QDC TFZ Headphone Upgrade Cable:
https://a.aliexpress.com/_mqN9rIb
4. US $60.33 | 8 core Gold, silver and copper mixed wire MMCX 2 Pin QDC TFZ Diy Earphone Cable for ZS10 PRO ES4 AS10 BA10 ZSN PRO:
https://a.aliexpress.com/_mK3csgF
The conductor / material noted in the 'specifications' section of each listing is 5N single crystal copper plated silver, even though the title of each one is "gold, silver and copper mixed wire".
Apr 5, 2021 at 5:13 PM Post #5,961 of 9,225
Golden fall doesn't include gold in it. So those look similar with goldenfall but not the material i guess. You can buy WhiteCrane equivalent as they use same copper material, furukawa copper, and the sound sigunature was not so different.
Apr 5, 2021 at 5:49 PM Post #5,962 of 9,225
Goldenfall is 4 cores. Just message the store and ask about it as I do not believe he has it listed. Or at least since last time I asked about it.
I also asked if the cables you posted were the same as the new KZ cables. He said no but wasn't sure about the specifics on the KZ cable. Looks very similiar.
Apr 6, 2021 at 2:13 AM Post #5,963 of 9,225
It does not say so in the description, but in one of the images it looks there are some gold plated strands, what do you make of it?
Apr 6, 2021 at 10:48 AM Post #5,965 of 9,225
Apr 6, 2021 at 11:49 AM Post #5,966 of 9,225
I have ordered the Nicehck Blackwheat and that KBEAR one too. I'll post here when I get them.
I've found a few others but the cables look to be a bit on the thin and tangly side:
Moondrop MKI
https://a.aliexpress.com/_msI6N4v
Upgrade Cable For Weston 1964
https://a.aliexpress.com/_mKibW2v
Hi, have you received and tried the Nicehck Blackwheat cable yet? Is it any good?
I've got a KZ ZS10 Pro with a Jcally 3.5mm cable with mic and it worked on my phone, but when i tried connecting it to a TypeC DAC to my laptop's type C connector, i can only get sound output, it just doesn't detect the mic... Which the stock KZ brown cable worked perfectly, both sound and mic comes through.
The idea is to be able to use the IEM for Zoom and Webex calls without having to use the laptop's mic which i had to lean forward towards the screen to let my voice be heard... Thus i got a cheap Jcally type C to 3.5mm adapter which works great i must say, even on my phone. The sound is much brighter and clearer compared to plugging into the 3.5mm.
The Jcally cable with mic is working fine with my phone... the mic is clear and the cable doesn't tangle like the KZ stock...
So I'm in a situation where i have to swap the IEM between the two sets of cables, stock KZ for zoom calls on laptop and the Jcally ones when I'm not on my desk and out and about...
Which is why I'm on the hunt for another alternative cable with mic.
Apr 6, 2021 at 12:04 PM Post #5,967 of 9,225
First XINHS batch took 5 weeks from ordering to get here. :joy:
https://www.aliexpress.com/item/1005002042493770.html
0.35 ohms.
Build quality as expected from XINHS cables, working chin-slider and is very soft. Not very thick though, despite having 8-cores. Cable B7.
Default silver cable rec.
https://www.aliexpress.com/item/1005001786868630.html
0.17 ohms.
Essentially a somewhat different looking cable A3 that is a bit stiffer, glossier and has a working chin-slider. Cable A3 is still recommended over this one due to the higher cost for basically the same thing (unless you need a working chin-slider, which doesnt work on cable A3). This is cable A11.
https://www.aliexpress.com/item/1005001843312645.html
0.19 ohms.
Build quality as expected from XINHS cables but non-working chin-slide. Very soft cable and is thinner than average due to only having 2-cores. Looks very unique due to the blue color. Cable A12. My favorite blue cable, probably be better if it was in 4 or 8 cores.
https://www.aliexpress.com/item/1005001742192708.html
0.22 ohms
Build quality as expected from XINHS cables but non-working chin-slide. Very soft cable and is average in thickness. Cable A12. Not recommended due to high price.
Apr 6, 2021 at 1:01 PM Post #5,968 of 9,225
Thanks @RikudouGoku for the run down on the batch. I do have my eye on that blue cable and I would be more interested in a thicker version.
The chin slider on the Limpid Pro was the same metal one as the Limpid. On the Limpid, the holes are too big and it is non-functional. On the Pro, the holes are too small and I won't use it. It is the metal disc vs the plastic ball on the XINHS version. IIRC, the TRN pure silver has more strands and might be slightly thicker.
Apr 6, 2021 at 1:03 PM Post #5,969 of 9,225
You can probably ask for a 4 or 8 core version on that blue cable. Although I wonder if it would pair nicely with their silver wire into a hybrid. :thinking:
