IEMusic
Darn it! I can’t have gluten.Now that we're using funky materials, what about cables with wheat?
Surely wholegrain is good for sound XD
I had to order one of these in 8 cores. It looks like a beast of a cable.
Haven't seen this store before has anyone got anything and recommend them?
£67.96 10%OFF | Cotton net shield Litz 8N single crystal copper upgrade line 2.5 / 3.5 / 4.4 interface
https://a.aliexpress.com/_BUydAp
Hey guys, just a heads up - alot of NiceHCK's cable are going to be ~50% off on the 24th. I'm probably going to force my wallet open for the C16-3 copper and a pair of KBEar Rhymes (back to $15).
There's not such a big deal here. They made prices up and now they show them as %50 off.Hey guys, just a heads up - alot of NiceHCK's cable are going to be ~50% off on the 24th. I'm probably going to force my wallet open for the C16-3 copper and a pair of KBEar Rhymes (back to $15).
I kinda guessed that they increased the prices to make it look more attractive, but I've never seen the C16s for less than 30. However tho, thanks for pointing out that QC thing, gotta reevaluate my cart now.I paid way less than that for the C4-1 a couple of months ago so think they've put the prices up to make them seem cheap when apparently half price. Its a decent cable for less than $80 any more and I think is too much for it compared to what else you can get.
Nicehck may be ok for $30-$40 cables but there are better brands to spend your money on when you start getting to around $100+. My Nicehck upocc that was $80 (currently $125) turned up with a bent 4.4mm connector so was unusable but they didn't seem to care. I'd honestly recomend a manufacturer with better QC & CS like Penon, Dunu, ISN etc. So in the unlikely event you have an issue they will actually deal with it and you won't be throwing your money away.
I purchased c16-3 for 20 dollars a month ago. So there's a slight amount of discount...
No, I think the price is the same regardless the connector but it differs when you want to buy with different types of plug. 4.4 one which I also purchased was the most expensive plug type.Oh man and here I thought I was at least gonna get a real good deal on c16-3s... Was that price for only the NX7 termination or was QDC/2pin also included? Cos I remember seeing a separate listing for the NX7 cables for cheaper.
I mean if you buy 100 of the NiceHCK cable, you "save" 100 usdniceHCKs version will be a $1 cheaper during sales day. Get one of them Rhythm cables from KBEAR those are a steal at the price.
Rhyme cables, I believe.niceHCKs version will be a $1 cheaper during sales day. Get one of them Rhythm cables from KBEAR those are a steal at the price.
Just a follow up, about this cable. I have not found a better all copper cable, regardless of price. This cable lays straight and stays limp, and is just a joy to use. I highly recommend this cable if you are looking for a good copper cable, that will give you all the benefits of pure copper, with zero negatives. This cable has a well balanced sound and I have it paired up with my Lyra II and love what I am hearing. This cable is the definition of a perfect copper cable.I finally just took delivery of a killer cable for a killer deal! The build quality is perfect, and it feels very solid with a bit of heft. This cable is also dead limp, so it lays perfectly straight. I am stunned at the quality of this cable for only $30!
Check out the quality of this wire!
AK **** 8 Core Upgrade High-end Single Crystal Copper Cable
