InstantSilence
What's the best bang for buck USB a to usb B.?
The best looking one.What's the best bang for buck USB a to usb B.?
Some have the 5v separated... So I was hoping for something that wayThe best looking one.
Its very smooth and supple.Does anyone own this cable and if so, how supple is it?
£24.27 | Tripowin C8 Silver Copper Foil Mixed Braided Earphone Replacement Cable IEM Upgrade Cable Tinsel Silver Wire Tinsel Copper Wire
https://a.aliexpress.com/_BSkbN8
Spot on thanks very much Anything else I should know?Its very smooth and supple
Any recommendations on a short 2pin 0.78mm cables that I can use for Bluetooth setup? I found Hiby cable on Aliexpress which looks interesting, and someone said dd-audio makes one. Any others? Fiio makes excellent LC-3.5-BS but that is an MMCX version, they do not make a 2-pin version of it sadly.
I have the Tripowin Zonie on my KZ ZS10 PRO and I love the combo. While I don't own the BLON BL03, I think it would work great and sound great. The cable is very well built, and quite soft and supple. It helps tighten up the bass, and give better definition and detail to the mids and highs, imo. If you can get it from Amazon, go for it. I ordered another one for the Urbanfun ISSO14 I ordered in March (in 2.5mm balanced, with an mmcx connector), both from the same seller on Aliexpress. Sadly, I never received my order and had to file a dispute on Aliexpress. Thankfully, I got a refund for both the iems and the cable. But I can say, from my experience, the Zonie is an excellent upgrade cable.Hello I need a cable for my new BL-03, preferably under $20.
... also never used anything other than Amazon so I don't know what to watch out for when using other sites.
Edit: If context matters I've wanted to buy the Tripowin Zonie, but I want to be open to other alternatives as well.
Edit 2: I probably also have to weight this against the fact that in the case of Amazon, a brother in law has access to amazon prime so it would be ordered through that.
Thanks, 45cm or 50cm max length and non-recessed 0.78mm 2pin connector that Empire Audio uses in their universal IEMsWhat length? You want 3.5mm single ended, right? Do you know if you need recessed or non recessed 2-pin?
If you don’t like that style, Chitty has others to choose from. Different colors, different wire materials, etc. Just contact him and tell him Slater from HeadFi sent you, and he’ll take good care of you
I do find it kinda strange I see no measurements of its impedance yet. Neither for gray nor for white/gold variant (and from what I understand from hakuzen, different colors often come with different materials, changing the impedance in the process although more often than not the effect is very minor). Or maybe I haven't searched hard enough... Or maybe it just measures like 200mΩ like any other generic 16 core cables and maybe it's too obvious to point out?I have the Tripowin Zonie on my KZ ZS10 PRO and I love the combo. While I don't own the BLON BL03, I think it would work great and sound great. The cable is very well built, and quite soft and supple. It helps tighten up the bass, and give better definition and detail to the mids and highs, imo. If you can get it from Amazon, go for it. I ordered another one for the Urbanfun ISSO14 I ordered in March (in 2.5mm balanced, with an mmcx connector), both from the same seller on Aliexpress. Sadly, I never received my order and had to file a dispute on Aliexpress. Thankfully, I got a refund for both the iems and the cable. But I can say, from my experience, the Zonie is an excellent upgrade cable.
Mmm...imho, you are overthinking it. The way I look at it, cables are just another form of tone control. Tips are another form. I guess it just depends on what you are looking to correct on the iems you are using. What are you looking to gain with your BLON BL03, with a cable swap? Is it a comfort or aesthetic issue? Are you looking for a sound change? These are just a few factors that play into the equation.I do find it kinda strange I see no measurements of its impedance yet. Neither for gray nor for white/gold variant (and from what I understand from hakuzen, different colors often come with different materials, changing the impedance in the process although more often than not the effect is very minor). Or maybe I haven't searched hard enough... Or maybe it just measures like 200mΩ like any other generic 16 core cables and maybe it's too obvious to point out?
I haven't found BL-03's impedance graph either, so I dunno how much output impedance affects it across the hearing range. Although I assume the coil's inductive effects don't affect the impedance much across its output range? And in general single driver IEM are for the most part immune to subtle changes in output impedance.
I wonder if someone has both color variants and either measured it or at least tested with their ears to spot any difference.
... and I'm overthinking this again. Don't I?
Yeah primary reasons for it is:Mmm...imho, you are overthinking it. The way I look at it, cables are just another form of tone control. Tips are another form. I guess it just depends on what you are looking to correct on the iems you are using. What are you looking to gain with your BLON BL03, with a cable swap? Is it a comfort or aesthetic issue? Are you looking for a sound change? These are just a few factors that play into the equation.
*** NEWS FLASH ***
I discovered something about the BL-03 today, that was previously unknown by the community.
I was carefully examining the BL-03, and I noticed that there is a fully functional bass vent right at the 2-pin plug.
This bass vent can get COVERED UP and sealed when the stock cable is used (or a banned brand that makes an upgrade cable using the stock plug ends):
However, when a generic 2-pin cable is used, the bass vent is fully UNCOVERED. This is due to the way the generic cable sits on top of the stock socket.
I tested this with different cables, and sure enough there is a difference. This difference is not due to the cable itself, but rather the vent being covered vs uncovered. I think this can explain at least why some people were hearing different BL-03 tuning, the (untrue) rumors of the different colors sounding different, etc. Some people said it had too much low end, others said it was too little, etc.
You can even test this with the stock cable, by partially unplugging the stock cable so that it unseals the vent. This proves that a stock vs 'upgrade' cable is not reason, but rather the bass vent.
The BL-05 has no such bass vent, and there is significant difference in the quantity of bass between the BL-03 vs BL-05:
Sure, the BL-05 uses a different shell and newer generation of driver, which does have some influence on the difference between the BL-05 vs BL-03. But the lack of bass vent on the BL-05 is a significant contributor on the BL-05 having less low end vs the BL-03.
