MIKELAP
No way... Tell me you didn't get ripped off buying expensive 6AK5/M8100/CV4010's did you?![]()
And guess by who TD........ you guessed it YEN AUDIO lol. Live and learn !
Hi, can I be a complete noob?
Going on the elation and advice on the forum for these tubes (6HM5 and 6GU7), I've ordered a set for my Little Dot MK III.
As I'm currently rolling a pair of 6H30Pi and pair of Mullard M8100, therefore the only thing I need to do to accommodate the new tubes is adjust the jumpers into the EF92 mode?
I'm fairly certain this is the correct thing to do, just wanted to make sure.
Thanks in advance.
Hmm, looks like I've got myself confused and they are just EF95s like the Mullards.
Sorry all.
. . . Just ordered 6HM5 Yugoslavian and 6GU7 tubes, many of you appear to enjoy![]()
Yes indeed,if your not careful your wallet might runaway from you.![]()
Although the 6FQ7/6CG7 tubes work as power tubes in the LD MKIII, I would not recommend them. I did try them, and there was something with them that was not compatible with the driver tube I was using (12AX7 family).
As driver tubes they were pretty good, and you could find real bargains in looking for 8V tubes - 8FQ7/8CG7. There are also 12V versions, but it seems that they are used in certain high end amps, and they cost much more.
What wallet??? They took my wallet too.![]()
Is there any solution to the 6DJ8 noise problem on the LD 1+ I may have missed?
Do the other options listed on Page 77 for the 6DT6 (6/7 pin mod and 2/7 pin mod) make any difference to the way the 6DT6 tube sounds?
Will the 5687WA modification with the external heater work with the LD 1+ (I assume yes as gibosi has advocated for this mod). Also is there a wiring diagram for this mod? I found the parts list that gibosi made but I have not found a diagram. I am hoping I may be able to salvage my box by using it with this mod.
Finally will the C3G mod work with the LD 1+ using the double adaptor modification?
That is a serious collection of Mod's and Cart's in your Avatar...
Vaping gear ramps up quickly in price too, at least here in Canada. I just picked up an Aspire mini Nautilus, and need a decent variable wattage battery to go with it.
This forum has been a such a drain on my wallet, and to think, I only came here to get some settings for my walkman (NWZ-A828).
I'm not very eloquent, but when the new tubes arrive, I'll try to compare them as best I can.
At least these tubes aren't as expensive as other things.
To All-- Are there any impressions about the combination of 6HM5s with 6H30PI power tubes? I ordered 6GU7s but wondering difference of these tubes versus leaving 6H30PIs in place and simply replacing M8100s with 6HM5s?
P.S., I'm not into vamping, but I really enjoy the decadence of a Cuban cigar with a single malt scotch, on occasion...
