gibosi
- Oct 18, 2012
I don't even need an amp! With 100s' of tubes, I can sniff getter gas all day long...
To be honest it is easier to have CRACK than SEX..................
Well I received a MOST EXCELLENT gift today, four Yugoslavians came to live here in Nova Scotia!
Running 6GU7's as power tubes in this setup and these little Yugo's sound incredible!
OK your incredible gift of four Yugoslavian's that came to Nova Scotia. It is not clear to me if all 6GU7 come from Yugoslavia it seems eBay sells one branded as Sylvania. Are those not the good ones?
So are you saying between Yugoslavian inexpensive 6HM5's and 6GU7 (inexpensive or not) you can have a complete plug-and-play replacement for stock tubes in the little dot IV MK SE which will be completely plug-and-play and pretty inexpensive?
The B+ on the LD III & IV is around 200V as well, I have not measured it specifically but all the filter caps are rated at 250V so it would not be higher or even within a few volts of that.
The transformer output is AC 175, multiply by sqrt(2) to convert from RMS and that gives you approximately 247 VDC out of the full wave bridge, subtract the voltage drop from the the filtering resistors and caps you are left with a usable 200VDC
Would the following adapters allow me to use 6DJ8/6922/ECC88 type tubes as driver tubes with the LD Mk 3?
http://www.ebay.com/itm/1x-6AQ5-to-6P1-7pin-to-9pin-vacuum-tube-adapter-socket-converter-02-/290973107611?pt=Vintage_Electronics_R2&hash=item43bf59459b
