dannie01
- Feb 22, 2008
CZ, thanks for sharing and trusted the LD VI is a good amp to drive with HD650, but do you think the good sounding from the LD VI is somewhat upgarded by the Apuresound V3 cable.
Originally Posted by cafe zeenuts /img/forum/go_quote.gif Sound comparison between my LD MK V & MK VI This is an apples and bananas comparison as we all know it, RCA Vs XLR. My old single end system, Source: CA840c AMP: LD MK V Power Cord: Volex17604 with wattgate ends. Cable: RCA BJ89259 and SAA Equinox HD650 classic Headphone: HD650 For a single ended system this setup sounds very good. Soundstage is good, bass is control, a neutral sounding amp with a little colour added to the sound. What I hear on my HD650 is a straight sounding CA840c, detail and analytical. With the smaller soundstage instrument separation is a little muddy. Floor noise is black. No snake Oil used for this single ended setup. New balanced XLR system, Source: CA840c AMP: LD MK VI, Gain setting on “LOW” Tubes: JAN Slyvania 6080wc and OTK 6H9C Power Cord: Volex17604 with wattgate ends. Cable: Signal Cable Silver XLR and 4 Pin APS V3 HD650 Headphone: HD650 Snake Oil: Vibrapods and Cones and Caig Deoxit Gold G5 My first balanced setup wow what can I say, I was blown away on stock tubes. Soundstage is massive 3D like, very Airy and spacious. Very high resolution and transparent, I’m hearing a lot things that was a little muddy on MK V but on the Mk VI it’s crystal clear. Timbre is excellent, the decay is long, bass is tight, mids are lush and highs is crisp. Susan Wong voice on XRCD2 sounds so sweet and Eagles hell freezes over XRCD2, hotel California sounds so real, like if you’re right there on stage just amazing. It makes my hair on the back of my neck stand up every time I listen to this track. The CA840C really shows its grunt and capability when output on balanced mode. Extra detail and wider soundstage better instrument separation compare to single ended RCA. Floor noise is black. Snake oil is used for this setup, Vibrapod and cone under amp and CD player, all tube pins and cable connectors are treated with Caig Deoxit Gold G5. YMMV!!!! Tube Rolling to come…. |
