JimP
- May 26, 2005
So to summarize for those getting LDVI:
1. get two quality quiet 12v 80mm fan (recommended so far: Noctua, Papst, Nexus, Antec, Scythe) I got Zaward, and examples of others: Quiet PC UK - Quiet Computer Fans for a Virtually Silent PC
2. unscrew 10 bottom plate screws (be careful, I already stripped one in my exuberance)
3. pull 3-pin connector from board (slight tug should release)
4. before removing stock fans, note carefully how the color coded three wires from each fan are spliced together (so the 12v fans are run in series to 24v feed)
5. prep new fans' wiring in same manner (solder and heat shrink tubing, I didn't have latter so I just used electrical tape to wrap)
6. attach new fans so air is blown into amp (this is very important, amp chassis is significantly cooler this way)
7. dispense with the fan protector cage (may not make a big difference, but could add to additional vibration). Also my fans came with rubber attachment thingies so I dispensed with the original screws as well.
8. replug the 3-pin connector to the board (it only goes in one way), being careful to make sure it sits flush. You may want to tape excess wiring to the base plate.
9. screw the base plate back on (do not overtighten, as you may strip screw head, like I did on one of the screws)
That's it, and now you will have a nearly silent amp compared to the buzz-saw of the original fans. (OK the fans are kludgie, but they seem to work - I hate to think how hot this amp will get without fans, even with fans blowing out (as opposed to blowing in), the amp got very hot)
[the above may be blatantly obvious, but it may be helpful to someone - like me - that's not so mechanically/electrically inclined]
Also, on headphone cabling, as others have noted, the amp can take 4-pin XLR (front) or 2 x 3-pin XLR (back). Do not be intimidated by this, especially with Senns as they have detachable cable. There are numerous cable makers that provide this.
And do not scrimp on source - I think that's a good part of the magic I'm hearing (I'm using XLR out of 840C, there's better but the 840C is enough for me)
The best endorsement of this product, is that I am having fun with headphones again.
