Finally got my "ultimate" amp up and running.
Well technically it's only my "ultimate" input stage design, the output stage is a standard sandman but you can't really go wrong with a sandman in a pinch. My real "ultimate" output stage is next on my list.
My efficiency went up like 5000% ever since I bought these solderless breadboards a week or so ago, I shoulda been using these for prototyping from the start I would have never been able to build this on anything else.
It was one seriously noisy beast when I first got it up and running, almost 10v of noise from 0-10Mhz all over. I managed to quell most of it but the solderless breadboards aren't the best thing to use for this.
Part of the reason for all the noise is the distance between the components and the power supply. It can't regulate all 3 boards effectively and my low bandwitdth opamp in the reg isn't helping things.
Even with semi-unregulated to unregulated supplies I still get this beauty
Blue is the input signal to the input stage, yellow is the output signal of the input stage through the other end of my duelund cap shrunk down. Not too bad for a poorly regulated input stage. This is my first time seeing such a good copy of a complex signal since I got my oscilloscope and it can be further improved with better supply regulation and a few other tweaks.
Actually the input stage is only using a C filter of a few thousand uf on the B+, no resistors or regulation which isn't good because the design is susceptible to poor power supply regulation and output impedance (so much for ultimate?)
Although to be fair I've yet to measure an amp with a regulated supply which may be why I often see way more imperfections in the amplified signal (you don't even want to see what the mk6 looks like in SE mode) but considering how this isn't regulated it's pretty darn good.
The sound is clear as a bell, micro detail galore. Nowhere near the euphony of the MK6 though which is unsurprising considering it should be very low distortion, although the clarity, dynamics, and effortless sound separation is in itself mesmerizing.
Either way I'm satisfied that the results meet my expectations and my design goals.
In theory as far as tube input stages go this really is the ultimate theoretical design if the goal is linear amplification. The only way to improve it is to use better matching tubes but even then I built circuits to compensate for unmatched tubes as best as can be done without some sort of digital software curve analysis and algorithmic matching or something crazy like that (which I would love to do).
All I have to use for a DAC right now is my ipod, interestingly it still sounds amazingly good, unlike my MK6 which is in euphony only mode right now since its power supply is a piece of garbage without balanced operation
I'm going for a DHT and a nutube version next before I build my "ultimate" output stage. I built filament regulators that should in theory far outperform the coleman regs so even the filaments will be ultimate.
Then I can put my focus into mastering distortion generation rather then distortion elimination. Which reminds me I should probably connect this new stage to my mk6 output stage.
