I bet the middle is same as our front end differential,
Then it feed two common cathode. .
2v LEDs and batteries can be found as well. LED will probably be red or green, the best ones are the vintage "dim" variety. The new bright ones get mixed reviews.
Overall batteries get better reviews, I've only heard good things. Lead acid batteries come in 2v and so do deep cycle batteries if you want to go balls to the wall.
Both are among the best sounding batteries if I recall.
Coin,
Now that you have your CCS I believe you should bring your attention to possible clever ways to achieve the effects a balanced topology does
OK I see,
So you will need at least this CCS to stabilize the triodes, in order to implement the cathode follower / grid drive mod...
Now count the amount of components (maybe custom chip, or mosphets, transistors, diodes,caps , and their separate PSU stage) in order to implement this.
Remember this is all to replace one coupling cap and one cathode resistor in our current amp..
Now this is where design choices are made.
Wich path will we decide to choose?.
This is exactly the point I am trying to make about the distortion cancelling abilities of the common cathode design.
As far as I have checked,
this driver stage implement almost textbook spec.
Yet you and MrCurwen kept pointing out amp by stating the driver stage is poor and non optimal.
In reality nothing is optimal.
We have to deal with what we have.
So our amp driver stage may not be perfect, but I have not notice anything poor in driver circuit except the tubes themselves.
Looking over the values it does seem this circuit is more for triode balance than the "common cathode" benifits of noise cancelling.
As an example about Sweet Spots in tubes,
I was able to increase my tube performance in sound stage with a slight increment of bias to rear power tubes..
Meanwhile,
I will listen to my amp,
which "shouldn't work" as good as it does.
Also the decision of the designer to a place the bias point lower. .
why?
I think because of heat and longevity and no fans on bottom MK8 unit!
The trick to eliminating this effect is to design the circuit so, that the tube's rp has no significant importance to the function of the circuit.
If you do DIY long enough, you will build several THE BEST amps you've ever heard, and spend many nights marveling how you couldn't even imagine how any sound reproduction system could sound any more realistic and musical. Then you design a couple of failed things, and then you design the thing that is again THE BEST, even better than the last one. Then you spend many nights.... etc. Continue until you run out of cognitive ability to understand more electronics. That will be your best then.
Open loop 0.001% (which none of you have heard unless you go to DIY meets) on the other hand, is good.
The balance of LTP is dependent on the impedance ratio of the tail versus the brances that leave from the cathode node upwards (tube, plate load, on both sides). If you put a LED as the 'tail', it has an impedance of around 10 to 100 ohms, depending on make of LED. What's your ratio then?
