coinmaster
After looking into proper mosfet biasing and source follower configurations I learned that my above example of the grid drive mod would work but it is far from optimal.
This is a better way to do it.
M10 is the source follower mosfet
M11 is another source follower
M12 is a constant current source (maintains a constant current)
The zener diode D3 puts the gate of M11 at a set voltage above the output, in this case 27v.
This makes M11 produce 20v at its source (depending on the mosfet and its bias). So the voltage difference between the drain and the source of M10 is always going to be 20v at DC.
The capacitor C12 feeds the output signal to the gate of M11 so the voltage difference between drain and source of M10 will be the same at AC as well.
The end result is that as far as M10 is concerned, it is sitting at a stable 20v even though the the source and drain voltages are all over the place.
M12 feeds M10 a constant current.
As current is drawn through R31 a voltage drop is produced which after a certain voltage thresh hold turns on the transistors Q12 and Q13 which brings the voltage on the gate of M12 to ground level.
After the the current decreases from this the transistors turn off, the end result being an equalibrium of current is maintained.
Typically transistors turn on at about .7v differential between the emitter (pointy end) and the base but if you add more like I did in the above example it makes them more sensitive and they turn on at a lower voltage which means they react faster and a more stable current is maintained.
So what does it all mean in the end?
Well the current source and M11 maintain a constant voltage and current across the source follower (M10) which means it is locked in place on the load line, no change in transconductance or linearity can occur, this also reduces the effective input capacitance since input capacitance is the sum of the capacitance between gate-source and gate-drain.
A source follower has pretty much no difference between gate and source voltage so there is no need to charge/discharge the capacitance between them and the voltage difference between gate and drain stays stable also meaning there is no need to charge/discharge the capacitance between them.
In the real world there will be small variations but this way the overall distortions remain minimal.
This means you should still probably choose the most linear part of the load line for the mosfet just to eek out every last bit of linearity.
Meaning you should probably have M10 and M11 be the same mosfet since you are feeding them the same current and preferably the same voltage so they will act the same which will prevent phase shifts,
I'm choosing the BUZ901 because I don't know the meaning of restraint and it is probably the most linear mosfet in existence and I'm going to feed it 3.5 amps @ 20v which gives an insanely linear performance even if the voltage/current wasn't locked.
I've learned a lot from this source follower design and I've already been able to greatly improve my upcoming designs with the technique.
However it is not a simple mod and it will not fit in case (especially if you want to run BUZ901s @ 3.5 amps).
This design can actually be used as the output stage itself and could drive speakers, which I fully intend to try next month. Paypal Credit, what would I do without you.
