Of course. I placed bias point more in midde of the optimum part of the curve, But optimal value, was stated higher,
Datasheets and reality are far different from each other. Most datasheets were done almost a century ago and some were hand drawn. This is why the only way to really know what your curves are is with a curve tracer.
Even a tube tester has a considerable margin of error so even when you buy matched tubes you aren't really buying matched tubes most of the time.
Datasheets are a general reference, even if they were accurate they would only be accurate for the tube that was tested since tube specs vary between each other.
I've been contemplating building a tracer but I am not yet sure the extent to which bias shifting affects the sound so I don't want to go overkill for no reason.
and the datasheet doesn't tell me what sonic gains were to be had. .
Well, maybe not down to the last detail but it does give you an idea. More linear parts of the load line = more accurate reproduction. Less linear = more distortion.
Also the decision of the designer to a place the bias point lower. . why?I think because of heat and longevity and no fans on bottom MK8 unit!
I don't know what your tubes are biased at stock but I don't think it the designer would compromise bias rather then buy some fans.
Meanwhile,
I will listen to my amp,
which "shouldn't work" as good as it does.
I remember you stating Yours was excellent also..
Yeah I can't argue with how good it sounds, I'm detaching myself from what I heard and am looking for design improvements regardless.
The amazing sound is why I became interested in improving it to begin with since a few component upgrades made such a huge huge difference.
Although technically I have no real passion for the subject of electronic design and I'll be glad when its over. But since I'm already down the rabbit hole I might as well explore.
