Hi,
I just got into Tube Headphone amp about two months ago. I bought a LDMKII and fell in love with the tube amp sound quality. Then I spent many nights researching and learning about LDMKIVSE. I decided to move up to MKIVSE and do the power supply mod to run 6AS7 power tube and use C3G"S" for driver tube. Then I thought getting a LDMK9 would cost about the same amount of money so I change my mind and was going to pull the trigger on MK9. Then I saw a classified ad of MK VI+ for less than the price of MK9. So I jumped on it and now I am a very happy owner of LD MK VI+. I just love everything about his amp. I really enjoyed listening to music with MKII but this MKVI+ is just so rich and silky smooth. I am not good at describing my feelings with words.
The person who sold this to me barely had it for few months and took real good care of it. I practically got a brand new amp for half the cost. Everything work fine except the bearing in one of the cooling fan was already going out. It was making a very low grinding noise. So I decided to change out the fan with one of those 15mm thick quite fans. But then idea came to my head. I had a laptop cooler that wasn't getting used and was just sitting in my closet. I took the bottom cover off on MK VI+ and just set it on top of the laptop cooler and it was perfect. No air escaped and the twin 120mm fan running at 1000rpm was blowing air into the wider area inside the amp.
Here are some pictures I took:
I guess you can use any kind of laptop cooler but this particular one has the temperature sensor so you know how hot inside the amp is. It has two speed: normal and turbo mode.
The model name is Thermaltake Massive TM. I think the TM stands for Temperature Monitor. It is silver on the side so I used electrical tape to cover the silver part to black it out.
Then I used the 3/8 inch weather strip on the edge of the case because it was sliding around little bit and I wanted to give it extra shock absorption and airtight seal.
This mod was so easy to do. No cutting, gluing, bending, nailing, screwing, or drilling needed. Just remove the cover on the bottom and set it on top of the laptop cooler.
I just wanted to share this with you guys because I thought maybe there are some MK VI or MK VIII owners who might be looking to replace their fan.
