tomscy2000
The logo IS braille for the letters LH!
You're right! My bad, thought braille only had two rows for some reason...
Legitimate reason to use braille as navigation, then!
@woodcans
Had raised the issue also about the design, Larry Ho assured me that its just a mockup. Final design would be determined later by their in house designer / Geek Force basing on the final specs of Geek Wave.
Some designs submitted in the GF Forum.
Folder/playlist support with shuffle/back/forward control is really all I need. The replaceable battery / size / weight is much more important to me. All I am after is a good SQ player that can replace my iPhone 5 with minimal fuss.
DX90 is not 300$ and also still hearing problems with the software on the DX50 so I will stick to the GW, if it does not meet expectations then selling it off and jumping to an iPod touch is what I am going to do.
What is the advantage of the femto clock upgrade??
