hmm so heres an interesting idea. Based on the pin out, does this mean that we won't be needing 3.5mm TRRS balanced to 3.5mm TRS Single ended adapters? Meaning if I buy a 3.5mm TRRS balanced cable for my headphones to use with the GO V2+, can I use the sample cable to use my headphones with SE outputs like my tablet and cellphone? Won't the L- and R- pins just get shorted together and act as ground in the single ended connection?
If I'm remembering correctly it really depends on what you insert into what. If you insert a TRRS plug into a TRS port then I think you're okay, as the two channels will just share the common "-" leg. However, if you insert a TRS plug into a TRRS port then things will not be good, as you're shorting across the different terminals in the amp itself. I believe that is why LHL put that red plug into the TRRS port on the V2 and V2+.
If I've got this wrong then please correct me my friends!
Not a bad price for the adapter. 3.5mm and 2.5mm balanced jacks are a pain to deal with when DIYing a cable, so it's good to see that there are some options on the market. I personally would prefer to buy an adapter from a trusted source and I'm hoping that we see some official adapters from LH Labs, otherwise I'll probably end up having a custom adapter made by a cable maker I trust.
The seller is Lunashops.com They are reputable. I've gotten tips and a few other things from them in the past with no issues, and several other head-fi members have used them as well.
Agree. I've used them before as well for a dual 3-pin XLR to 2.5mm TRRS adapter to allow me to connect my Infinity to my CDM. Worked well.
Just ordered the 4-pin XLR to 2.5mm TRRS and also the 4-pin XLR to 3.5mm TRRS to allow me to listen to my LCD-3's on the CDM and the eventual Wave using my Moon SD V3 balanced cable. Having the extra adapters is also good at shows so you don't have to swap cables as much.
I'll third this one. I've also used Lunashops to great effect in the past. They're not local and you can't go next door to check in on them, but they're as dependable and consistent as I've found.
The battery takes about 2-3 hours to charge the 3000mAH battery. I'm so used to my quick charge phone that I forgot a charge could take that long. It seems to last me for my morning and afternoon work commute the entire week on the lowest gain setting. (10-15 hours ish) I left the device on accidentally a few times so I need more time to see how long it actually lasts.
Sound wise, this could easily be my desktop DAC. I tried it via Jriver and Foobar and it is my favorite DAC/amp to date. It is more enjoyable than my Audio-GD NFB 11.32 ever was, and I haven't even tried it balanced yet. At the initial backer price, it's a total bargain (for the Infinity). It easily surpasses the V1 as well.
If you got in when it was called the Geek Stream (very early backing), it ended up being less than $250 for the V2+ Infinity.
Despite the wait, nothing on the market is anywhere near as good sound or spec wise for the price of up to $450 IMO. The new Sabre chip is a beast and isn't as cold/shrill as past Sabre chips.
I'm holding off on a full review until I can try it balanced.
I am stuck contemplating between the apogee groove and the GO V2+ I have a loaner groove unit and its such an upgrade over my macbook its not even funny. I wonder how well the groove compares against the V2+?
Not gonna lie, so jelly right now, a steal of a deal
I'm also looking forward to trying it balanced, but like many, my balanced gear is 2.5mm or XLR. Going to have to snag an adapter at some point to use the balanced output.
