The case looks better there but a can't unsee the indent right next to the 3.5mm output. Looks like it was pressed in when inside a pocket or something was placed on top off it. Not sturdy at all! Hopefully that's not a production "blemish".
LH Labs Geek Out v2+ Discussion Thread
- Thread starter Lifemovingforwa
- Tags
- lhlabs-geek-out-v2
bhazard
- Jul 15, 2013
Great, now I can't unsee it. lol
It's a shame how poor the case is, because sound quality wise this is the best dac/amp combo I've ever owned. It surpasses my old Audio-GD desktop unit.
vhsownsbeta
- Jun 28, 2013
The latest indiegogo update mentions a case revision to include some aluminium, to the point where further V2+ shipment has been put on hold. I kind of wish LH would just admit to themselves 3d printing isn't ready for this type of application and revert to a V1 style chassis...
rcoleman1
Wow. That's an awesome impression but I'm gonna hold out for a casing improvement before I jump in.
dacfun
- Sep 1, 2015
The case looks OK to me. I guess I am in minority, but I prefer it that way - I care most about the great sound, don't care that much about the case as long as it functions flawlessly.
dacfun
- Sep 1, 2015
New pics.
I noticed you use the single ended output. Don't know what headphones do you use, but with my HE-560, it was big improvement when I got a new balanced cable and started using the balanced output. Might be a good idea to try with yours as well.
sahmen
- Apr 6, 2014
Well, in order to use a balanced cable with this unit, would you need some kind of adapter? I have the hifiman he-500 (and also the He-6, although I'll probably not use the He-6 with the GO V2 +), along with the Sennheiser hd 700... All of them are equipped with cables that are terminated with 4-pin XLR balanced connectors...
Do you know how one might connect these headphones to the GO V2 + in balanced mode? Would one need some kind of adapter in order to make this happen, or does Light Harmonic have some special cable in mind for this purpose?
dacfun
- Sep 1, 2015
I first made one myself from the original cable - replacing the 6.3mm jack with 3.5mm TRRS. But also ordered higher quality cable on ebay, and that's what I use now. The pin-out is documented here: https://support.lhlabs.com/support/solutions/articles/5000634421-geek-out-v2-user-manual- (for some reason it is not in the V2+ manual, but works the same with V2+)
dacfun
- Sep 1, 2015
I replied in previous entry, but it is held for approval (I am new on head-fi). The most important info is the link to the V2 manual, which includes the balanced 3.5mm pinout. (it is not included in V2+ manual, but is the same)
sahmen
- Apr 6, 2014
Thanks man. This is very helpful.
HIFIMAN also makes their own cable. They use the same pinout as LH Labs, so it'll work just fine. Won't do anything for your HD700.
http://hifiman.com/products/detail/133
bhazard
- Jul 15, 2013
I ordered this cable for the balanced output:
http://www.ebay.com/itm/3-5mm-Silver-Plated-TRRS-Re-Zero-Balanced-To-4pin-XLR-Female-Cable-For-Amplifier-/251992929864?var=&hash=item3aabf2f648
I'll be using a modified balanced AKG 7XX when it arrives.
Not a bad price for the adapter. 3.5mm and 2.5mm balanced jacks are a pain to deal with when DIYing a cable, so it's good to see that there are some options on the market. I personally would prefer to buy an adapter from a trusted source and I'm hoping that we see some official adapters from LH Labs, otherwise I'll probably end up having a custom adapter made by a cable maker I trust.
- Jan 1, 2014
Thanks for the link. Will the pin configuration on the 3.5mm TRRS work with the Geek products?
