mattmc1228
- Feb 14, 2016
Se 846. What device are you using?
I have the hifiman re 2000 sound really good, but fitment is an issue.
1) The V30 can drive the Shure's?
2) What volume are you able to get it to until it becomes too loud? I realize this is subjective.
3) How does your combo sound running Tidal Masters directly through the app?
Are you content with it?
You are welcome!Thanks to the poster that recommended them btw!
Also make sure you choose 'bitperfect' playback from the HiRes Audio menu. Once both of those are selected and you choose a MQA selection (like Southern Avenue), you should instantly see MQA in the status line--no reboot needed for me. Very nice Tidal Interface,,,
Just for your own education... the Qualcomm DAC DOES have the ability to decode DSD, but no OEM makes use of it.The Internal Qualcomm SoC doesn't have the ability to natively decode DSD. To activate the dedicated DAC, the headphone jack must have something such as a headphone or line out cable to function. The dedicated DAC is designed to be with the 3.5mm headphone out. It serves no other purpose if not connected. Not even Bluetooth.
The latest version of UAPP will play DSD .iso files correctly!
Strange as Neutron gave me nothing but problems, and UAPP works perfectly! So strange! But I don't need the high impedance mode activated, so that it one less issue (I use SE846).
New question. I'm going to set up a mid-fi rig for my HD650s. I've got an amp. I was hoping to use the V30 as a source realizing it will work fine but I'll be double amping even though the V30 has an AUX output. Aux isn't a line out signal and is amped. That's been bugging me.
So, new question is I'd like to use the V30 as a primary source. Is there any drawback in sound quality outputting USB to an external DAC the to my amp using the V30? Is there a reason to not use the V30 as a source vs other dedicated sources out there?
I would like to have one source for all my music. Portable and hooking up to my home rig. And I'd love if that could be the V30, but I can be flexible.
So with the V30(+), can we say that there's no need for a high end DAP? I'm asking because I've been eyeing up some DAP's on this forum but then I forget I own a V30+. Anyone agree?
Neutron is not bad but what I hate about it is:
Volume stepping is stock android when in player, it's amazing that the other player apps don't have this issue (i.e. Player Pro, UAPP).
I got use to the UI, but it's clunky
My biggest issue with UAPP is the volume, What is wrong with it? I have no idea.
