randytsuch
- Aug 31, 2002
I've been playing with the L20 H910 (ATT unlocked) phone I bought from epay.
Bought an open box one, but is was in a sealed box, and as far as I can tell it's brand new.
Using as a DAP, so now sim, I just ignore the missing sim message and it works fine.
Battery has been draining fast, so I just put it in airplane mode but then turned wifi and bluetooth back on. Hopefully this will make the battery last longer.
I think not having a cell connection may make it work harder.
I decided to root oreo into it. Had some problems, all because I didn't follow the instructions right.
Then I watched this video, really good, but long, but highly recommended if you want to root
The video roots nougat though, oreo is a little harder, but it's working fine now.
Oreo provides options to
And I thought I bricked the phone at one point. But I found some advice at https://forum.xda-developers.com/ and was able to revive it.
I'm pretty sure you can really screw up the rooting process, and still be able to bring a v20 back to life.
Oh, and its really fast, with really good wifi and bluetooth connections. Something daps don't seem to have.
Have only listened to it a little bit so far, mostly have been getting it setup. Sounds really good from what I can tell
Using UAPP, had bought it a long time ago. Great player for the v20.
Randy
Randy
