Andrew_WOT
- Jan 18, 2004
If it's so linear why EQ is a must then?I might agree. LCD-X is so clean and linear.
To accentuate the midrange - I like it as it is without EQ. Especially with music that leans more towards aggressive in style and mix (metal bands specifically are guilty of these)If it's so linear why EQ is a must then?
Makes sense, thanks, but this is far from linear as stated above, that was my point.To accentuate the midrange - I like it as it is without EQ. Especially with music that leans more towards aggressive in style and mix (metal bands specifically are guilty of these)
Idk I think linear might not have been the best term used to describe the LCD-X but I do think a lot of what determines a headphone’s character is the “tilt” of its fr (whether the average when compared to harman tilts downward or upward) and I think in the case of the LCD-X it stays fairly flat if you count the upper treble.Makes sense, thanks, but this is far from linear as stated above, that was my point.
Idk I’ve never heard the XC but it kind of just looks like every other harman-tuned headphone on the market right now except it’s heavy and giant.Really not a big fan of EQ, from the camp of phones should sound different the way they were created.
With that in mind, would LCD-XC be a better choice with out of the box tuning, I am reading mixed reviews on both, some say soundstage is about the same and they are more even, same say that LCD-XC sound too closed in and miss low end in comparison to open counterpart.
At the moment my favorite is HifiMan HE-6SE v2, should I even bother with LCD-X (C)?
IMO harman is not linear and this is a fantastic linear headphone sound for mixing and mastering.Makes sense, thanks, but this is far from linear as stated above, that was my point.
If you can afford it.. I’d suggest getting the Sonarworks Sound ID reference software. It takes all of the guessing out of the equation regarding equalization and really helps these cans shine.Pulled the trigger on the LCD-X to complement my Auteur, I was hoping to avoid EQing them since I have never done it before.
IMHO it's not really worth getting those to use without EQ.
Out of the box they sounded a bit off, maybe fake would be the right word.
I just used the peace EQ to bring them closer to harman using Resolve's measurements and oof.
I used to own Sundaras so the planar bass wasn't something new to me but that punch and rumble sure was.
The only thing that turns me a bit off for now, is that im not super used with the idea of EQ yet and "messing up" with how they are supposed to sound.
Otherwise seems to be an excellent headphone with great value.
EQ Is kind of a nightmare if you are not down with resampling. Roon is a workaround but it’s pricey.How do you guys EQ streaming services, from what I've read that requires shared mode which picks up sound from other apps and resamples everything in OS Mixer.
This may help in sorting out your EQ worries, when using an EQ this will tell you what EQ values to set if you're looking for the Harmon shelf sound (if I even said that right, I'm still new here).Pulled the trigger on the LCD-X to complement my Auteur, I was hoping to avoid EQing them since I have never done it before.
Nice one! Do you have one for the LCD-5?This may help in sorting out your EQ worries, when using an EQ this will tell you what EQ values to set if you're looking for the Harmon shelf sound (if I even said that right, I'm still new here).
I use MathEQ to get these values personally.
https://www.dropbox.com/s/sloaf7ptogjmjkx/Audeze LCD-X (2021 revision).pdf?dl=0
