LCD-X and XC Update
Aug 26, 2021 at 4:48 PM Post #961 of 2,740
Hi all, considering the LCD-XC 2021 and Aeon 2 Noire and not sure whether the Audeze is worth £400 more than the Aeon (£1259 vs £849). The comfort of the Aeon seems very appealing but many reviews say it lacks dynamics
...not as much macrodynamic heft as XC IMO..microdynamics...= bags of it.
I keep both for different purposes.
Aug 26, 2021 at 5:40 PM Post #962 of 2,740
I own lcdx and aeon 2cb with noire pads. I wouldn't sell aeons to upgrade to lcdxc.
Aug 26, 2021 at 5:45 PM Post #963 of 2,740
For all interest in the difference between the old XC and the new 2021s my review is online. :beerchug:
https://www.head-fi.org/showcase/audeze-lcd-xc.16792/reviews#review-26552
Great review! Mostly similar to my experience of LCD-X 2021 in terms of the new revised drivers technical performance, the transient response is definitely improved, way faster and low frequency doesn't thicken up things :D
Did you try swapping your Bubinga Cup to your 2021 version driver to see if it make another deifference? Aesthetic definitely make a difference XD
Aug 26, 2021 at 10:03 PM Post #964 of 2,740
Sorry no experience with the Aeon 2 Noire, maybe someone else can help.
In the meantime, I wanted to share these:
New semi-custom headphones measurement setup (ignore the actual cable routing).
Aug 27, 2021 at 10:01 AM Post #966 of 2,740
Decided to go with the XC. How are they without EQ? I'm not much of an EQ guy
The XC have the advantage of very low distortion, even at higher volumes, which makes them ideally suited for EQ. The only thing you will need to consider is how clean your amp is at higher levels of power output. Every 3 decibels of EQ will need twice the power driving the headphones. Past modest adjustments, this increased need for power may present a problem if your amp is already near its limit. However, if your amp is up to it, you can dial these in with EQ to suit your taste without losing quality. In particular, a fat bass shelf will make these headphones really thump.
Aug 31, 2021 at 1:50 PM Post #968 of 2,740
Did anyone ever measure the newest version of the ldc-2f like they did with the lcd-x?
I own the lcd-2f and its perfect for my needs and was curious as to what the graph looks like compared to the older version of the headphone.
Aug 31, 2021 at 11:28 PM Post #969 of 2,740
Sep 1, 2021 at 12:30 AM Post #970 of 2,740
How much power does the XC 2021 need compared to the Ananda? More or less?
Very similar in actual power needs. Though I EQ the LCD-XC a little more (6+ db bass shelf) so in my setup it is a little hungrier than the Ananda. They both run really well with my JDS Labs Element II. So nothing real crazy required.
Sep 2, 2021 at 12:38 PM Post #972 of 2,740
Sep 2, 2021 at 12:44 PM Post #973 of 2,740
Is LCD XC out of stock? Why do I have to wait 2 months to ship it to me
The official Audeze store on Amazon shows delivery date for September 5th. When I ordered mine the Amazon store had zero available. I ordered direct from the Audeze website and it took twenty-four days to my door.
Sep 3, 2021 at 3:52 AM Post #974 of 2,740
Hi bro, may I know which date you ordered on audeze website ? Since i asked audeze cs and they told me it will take more then 2 months for LCX XC shipment.
Sep 3, 2021 at 7:26 AM Post #975 of 2,740
It was toward the end of June. Received them in July.
