Jun 29, 2023 at 7:16 PM Post #2,536 of 2,958
I haven't checked into this thread in a while -- last I checked with Audeze about 6 months ago they were not selling the shorter headband anymore. Did that recently change I assume?
You have to email customer support. They will also suggest the video posted above if you don't want to pay extra.
Jul 3, 2023 at 2:30 AM Post #2,537 of 2,958
I have LCD X 2021 and LCD XC carbon 2021. The LCD X features a wider Sound Stage than XC and a better Bass than XC. The disadvantage is that the resolution is lower than that of XC and the high-pitched sound is rough. On the other hand, the characteristic of LCD XC is completely opposite of X. The high-pitched range is clean and the resolution is good. However, the disadvantage of XC is that the Bass is weak and the quality of the Bass is not good. XC also has a strong reverberation of Bass. On the contrary, X has a high-pitched reverberation. Personally, X is okay, but I think XC, which has higher potential than X, is a higher grade. Of course, it is the standard when applying EQ.
Jul 4, 2023 at 2:39 AM Post #2,540 of 2,958
Is there anyway to remedy this pad or I should just buy a new one? Try wet wipes but no luck
If it's the leather earpad give it a good dose of quality leather conditioner.. my favourite ritual
Jul 9, 2023 at 3:37 PM Post #2,542 of 2,958
I'm in. **ing made it - new LCD-X 21 is on my head right now.
Jul 9, 2023 at 3:56 PM Post #2,543 of 2,958
I know a great chiropractor...
Joking 😀, he's terrible
Jul 10, 2023 at 12:49 AM Post #2,544 of 2,958
Here is an unusual pairing … that works !! Audeze LCD-X (2016) driven by Grado RA-1 (twin 9V battery power). Synergy! Completely silent background, LCD-X detail & dynamics really come through ==> 🎼🙂🎵.
Jul 10, 2023 at 11:25 AM Post #2,545 of 2,958
Here's the measurements of my unit for statistics (if any)
Jul 10, 2023 at 8:14 PM Post #2,546 of 2,958
I've never had leather pads so big and plush and comfy and hot. Anyone have any luck cooling these down with aftermarket pads? I love how these sound, but can't enjoy them for more than 20 minutes without the heat becoming uncomfortable.
Jul 11, 2023 at 7:05 AM Post #2,547 of 2,958
I'm thinking about Dekoni fenestrated pads -but more to lessen that vacuum effect in the cups (also they could appear to be cooler. It seems to me that after getting hot in stock leather pads my ears start to cool down, but yes, initial warm-up is still there). I don't know (or at least I didn't try) if anything can be as breathable as Hifiman Arya\Edition XS pads, so reducing vacuum is my only concern.
By the way do fenestrated pads reduce bass or add highs? I remember some users mentioned this dozens of pages back ))
Jul 11, 2023 at 10:41 AM Post #2,548 of 2,958
Anyone else got different pads with their unit? : )
I thought that one side felt a bit softer, and now I'm sure) One pad is softer than another so it feels disbalanced on the head.
Anyone lucky? )
Jul 11, 2023 at 11:27 AM Post #2,549 of 2,958
Anyone lucky? )
Yup, that's not right. Time to contact the seller, I think.
Jul 11, 2023 at 12:55 PM Post #2,550 of 2,958
Anyone lucky? )
Pressing in the cups together like this is a surefire way on damaging the drivers due to the air pressure caused.
Don't ever push your cups together like this. We're talking about a very thin piece of film thinner than human hair being subjected to an immense amount of built up pressure.
This can cause premature crinkling, or outright kill a driver.
Planars are not like dynamic drivers. Exercise caution when it comes to pressure.
Audeze Stay updated on Audeze at their sponsor profile on Head-Fi.
https://www.facebook.com/AudezeLLC https://twitter.com/audeze https://www.audeze.com/
