xtasi
- May 15, 2010
How does EQing the bass up do?
Also, how does it sound with an amp after burn-in?
After burn-in, the KRKs do seem to even out a bit -- the bass increases a little, and the treble decreases a little. I'd still say that they're definitely a bright, relatively bass-light headphone by nature though, and no amount of break-in will change that.
How do i burn in ... is it just leaving them on maximum volume for a good lot of hours.... and yes this is a very good review. i just received mine in the post today after ages of waiting because none of the stock arrived in the UK. So i opened them and went upstairs and wacked up itunes. i first plugged my Sennheiser HD205's into the computer which i've had for the last 2-3 years. and listened to a particular song.... sounded brilliant.. then i plugged in My Kns-8400 and i noticed that the stereo field seems slightly mono and not so much spread between the two ears. the bass response was flimsey and the the mid high seems dipped. but apart from that they are super comfortable. and being professional about headphones... will this burn out thing increase bass response becuase i want to be mixing with these headphones on my logic studio and if the bass is too quiet its gonna be two loud for everyone else..
im just thinking about sending them back... because i'm not happy that i've paid £149 and waited a few months for them to arrive from HTFR and the sound quality is just rubbish. and the fact that my £40 sennhisers blew them out of the water annoys me even more... whats stopping me is the fact that there so comfortable. and mabye my sennheisers sounded the same when i started off with them... but this burn in thing do i just play it maximum volume from a computer. and im really hoping the bass improves becuase i just cant mix with these if there gonna carry on being naughty. but cheers alot for the reply
Hiya guys, I'm new here, been lurking around for a while thoughI really appreciate the in-depth reviews you guys give! I'd like to know how these headphones isolate. I've been reading through a couple of other reviews on the net that I found so far, but none have mentioned this yet. I've got a Sennheiser HD280 pro headphone needing replacement (after breaking most of the headband, and a slightly out of whack driver on the right side) here, so I do know there's going to be a big (huge) difference in sound, but that's not my main concern right now, as I've been using a set of KRK V8 studio monitors (with V12 sub) and I'm used to the sound. The HD280 is mainly used for traveling in the subway or bus/train/plane, because of their amazing noise suppression, and because they leak virtually no sound. (I do not want to bother other people when I'm enjoying my music, unlike some other people with the standard iPod earbuds seem to love doing) Could any of you give me an indication on this matter? I do a fair bit of "critical listening" to my own productions and to flac rips of my favorite cds, and I'd like to be able to do that in more crowded surroundings then my own studio space or living room
I'd love to go and try a set myself, I just don't have the time to go to the other side of the country to try them yet. Thanks in advance
And a small edit: If I'd want to replace the cable which you guys have flagged as annoying, do you have any suggestions for a better quality cable? I'm used to coiled cables (with the HD 280) and I would certainly like the extra mobility that such a cable gives me. Have any of you tried replacing the cable yet? And if you have, what were your experiences while doing that?
I am looking at purchasing the KRK's, But I am torn between them and the Denon AH-D1100. The KRKs are a bit more money, but I could go there if they are worth it. Does anyone have experience with both sets of cans, and if so, how would they compare?
I am in a remote location with no decent pro-audio for testing or demoing. My only set of headphones for reference are the Senn HD205s, which I find horrible uncomfortable and not very sensitive (they need max volume from the ipod before getting loud). Thanks in advance!
