Fuzziekiwi
- May 20, 2012
I know, I'm just saying you need an amp to make it louder if you watch a lot of youtube.
Question,
When I buy the DJ100's again, I won't be using it for my iPod, just desktop. What are some good desktop amps for $50 and under (if there are some)..? Can the fiio E6 be used with a desktop?
Also I remember reading a comment from you that said the DJ100 tends to pick up the sound signature of the device you plug it into, is that still true?
I just remembered when I had them a while ago that when I plugged them into my dad's reciever, the DJ100 had almost as much bass as Sennheiser HD439's. I miss my Koss already!
Hi head-fi experts!
I ordered the Koss Pro DJ100 on Amazon the other day and they will be at home tonight.
I read the reviews here and most recommend a portable amp with this device. I plan to use this with a Samsung Galaxy II and a laptop. I really do not want to buy an amp with this since I do not want to carry it around.
Would the Samsung Galaxy II and a laptop be able to give me good sound?
The Samsung Galaxy II would probably make them sound better than the laptop I imagine. Depends on the laptop I guess. Some headphone jacks on laptops are very noisy. Mine is so bad it's unusable.
Some amps like the E5/E6 are super small though.
I've actually found that my favorite source for the DJ100 is the Sansa Clip+. That device should be perfectly OK I'd imagine.
The newer Intel i series laptops are pretty decent. My Galaxy SII skyrocket has AWFUL sound output. I honestly think a laptop would be better.
From what I've read on anandtech it's the crappy Yamaha DAC in the new Samsung smartphones that makes them sound so bad. The Galaxy S still has a Wolfson DAC, so it should sound much better.
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3
Looks like I have to upgrade from the Samsung Galaxy S II to the Galaxy S3
Looks like the Wolfson DAC will not be in the US Samsung Galaxy S3..
http://www.androidauthority.com/samsung-galaxy-s3-wolfson-audio-chip-97729/
