tdockweiler
I would skip the Clip Zip and try to get the Clip+ (and a 16-32gb memory card!) or Sansa Fuze. The Clip+ sounds better than the Fuze to me, but supposedly they use the same chips.
I think the Clip+ measures better than the Clip Zip.
I don't know how well the Zen Plus will drive the DJ100, but it's worth a try. If the DJ100 has sloppy bass or is harsh and fatiguing, then it's amping issues.
I use and like the E5, but E6 should be similar. The Sansa Clip+ and the E5 is definitely a good match for the DJ100. If you use the Fuze, it's best to use the headphone out jack to the E5.
Believe it or not the Clip+ drives the DJ100 as well as my old Ipod Touch and Ipod Classic 3G, if not even better.
I think the Clip+ might be discontinued, but not sure. It's worth buying on Amazon if you can't find one locally. I paid only $30 for my 2g version (16gb MicroSD card!) and it's a steal.
I have the Creative Zen V Plus and was wondering if this could drive these headphones without an amp. If not, then I'm considering buying this combo.
Koss Pro DJ100
Sansa Clip Zip
2x M50 Pads
FiiO E6 (any experience with this and the Clip Zip/Clip+ ?)
