@barondla ...I don't discuss sound differences in SS amps but thought these specs below would be helpful in you determining the relative value propositions...
FWIW, if I were going to get a different amp for these it would most likely be tube based (SRM-T1 etc.).
That said, I personally don't see the value in doing that. If I were going to spend in the $1-2K range for an electrostatic headphone set up, I'd probably look at the Stax combo systems with either the SR-L500 or the SR-L700.
Koss ESP-950 Energizer/Amplifier.
Frequency response: 1.6Hz–50kHz ±3dB at 100Vrms differential output.
Input impedance: 100k ohms. Input level: 1Vrms for full output.
THD+noise: 0.001% at 1kHz and 100Vrms differential output.
Voltage amplification: 60dB.
Channel separation: 80dB at 1kHz, 100Vrms differential output.
Audio output voltage: 600Vrms differential, 2300Vrms push-pull with soft limiting.
S/N ratio: 100dB at 100Vrms output.
Bias voltage: 600V DC.
Stax SRM-1/MK-2 Professional Amplifier.
Inputs
There is one loop-through line-level input.
Rated 100 mV, 50 k Ohm.
Loop-through means they are wired together; you can insert this in between any two other components, and even if it's turned-off, the signal goes through.
Gain
60 dB (1,000x).
In other words, a 100 mV input can produce a 100 V output at maximum gain.
Frequency Response
Rated DC - 20 kHz, ±1 dB, at 30 V with one pair of SR-Lambda.
Distortion
Rated 0.01% THD at 1 kHz.
Rated 0.05% THD at 100 V at 1 kHz while driving an SR-Lambda.
