JimL11
Yeah, can't afford a BHSE. The T1 would need to be modified to work with the ESP 950? And you'd recommend that over an SRM-1/MK2? Would that need to be modified as well?
Well, the T1 doesn't have to be modified to work with the ESP950. However, it would need to have its old electrolytic capacitors replaced as routine maintenance, and modifying it by replacing its output plate resistors with constant current loads would more than double its effective power. Both the cap replacement and constant current load parts would be about $100. The mod is described in an article in AudioXpress July 2017. I haven't listened to an SRM-1/Mk2 but the SRM-727II with global feedback mod is considered to be one of Stax's best solid state amps and I prefer the modded T1 to that. Note that the SRM-1/Mk2 is as old as the T1, if not older, and would also need its electrolytic caps replaced if they are original. The SRM-1/Mk2 also uses resistor output loads so changing them to constant current loads would likely also be beneficial, although I don't know if anyone has done so and reported on the results.
