- Aug 20, 2013
Isn’t CCA20 coming out soon?
Umm...maybe???
Umm...maybe???
@Slater The ones with the "sharp" lip (far right) came with the ZS4 and one other model. Can't recall which. ZSN came with a standard set of 'Starlines' and a smooth medium tip pre-installed.
They are softer than the previous ones ?
I distinctly remember the medium tips on my ZS3E being the ones on the far right, while the small and large tips were the regular starlines(middle in your picture). I found it really strange while unboxing, that's why I took note. I don't know if that's the same configuration as in the ZS4 as I don't have it.I need a favor. If someone can help me.
I took comparison photos of the 3 different Starline tips (all medium size). You can click any of the photos for super jumbo photos.
The old (grey) one is on the left, the 2nd revised version is in the middle, and the oddball is on the far right. You can see the how the other 2 look "flat" on the top edge, and the far right one is "sharp" on the top edge:
Here you can see how the walls of the tip are thicker on the 2 original ones, and the walls of the far right one is thinner:
Here you can see how the 2 original ones have a smaller bore, and the far right one is slightly larger bore. It's not larger by a huge amount; perhaps ~1mm:
Here's what I need help with. I thought the far right one came on my ZSNs or maybe my ZS4. But I double checked and now I don't think so now. I some how got which came on what all mixed up, and now I don't really know what model the far right one came on. It could even be the ZS7, who knows.
Could someone please check their tips and let me know which one the far right one came on? I need to know with 100% certainty which model the far right one came stock on (ie the one with the "sharp" top edge). It seems to have only come on ONE model.
The one in the middle is the most common type, and is the type on all current KZs.
I want to know about the one with the sharp edge, not the one with the flat edge:
Thanks a bunch!
So, I guess the question is: is it really a 0.75mm or a 0.78 that will actually fit? I've read that a few people have used a 0.78 2 pin and it will work...but some have also said that once doing so, if you try to go back to a 0.75, it will fall out or no longer fit snugly. Am wondering if the 0.78 stretches out the receptacle hole enough to make the stock 0.75 KZ cables unusable. Any thoughts?The one I am using with my ZSN is from the first link... no problem at all.
I have the balanced plug.
It sucks that there aren't more physical brick & mortar shops around (like in Japan or Singapore for example) in North America or Europe, where people could test out these products for fit and comfort as well as sound quality. The biggest problem is not being able to try out how they fit. This is the same reason why I still buy clothes and shoes in an actual store and not online...you cant buy stuff like this just based on specs and descriptions. Its gotta actually fit your unique shape.Same here, lol. I've got relatively small ears and their size is the only thing that more than once kept me from pulling the trigger.
Looking forward to more if your impressions. I'm narrowing it down to ZS7 and ZS10 Pro for KZ stuff. Still got my eye on TFZ King Exclusive too. The cost of the KZ's are definitely a more affordable option, but the ability to upgrade cables from a 0.78 single ended to a 0.78 balanced with a regular recessed port and cable termination might be the deal breakerSorry if the ZS7 is old news, but I have about 100+ hrs on it now and I could have easily just stayed with this one. It is a really fun sounding iem with good clarity. It doesn’t play nice with my AK380, but it sounds incredible with the Lotoo and AP80. I put the not quite burned in ZS10 Pro in for a bit, and I can tell an increase in clarity over ZS7, very similar sound signature but I think separation might be better and spatial cues are improved. Might be my imagination, but I think I’m getting some front to back separation too...I’ll run it in a few more days and compare it to my ciems too
It sucks even more if you happen to live on an island somewhere in the atlantic ocean. The nearest B&M store I know of is in Valencia (Spain), 1874km/1164mi from here as the crow flies. Those folks carry a really decent selection of IEMs (Campfire & Co.) and offer a 14 day money back guarantee but most shops on the mainland don't ship anything to the Canaries because it's a special zone with it's own fiscal system (think of a paradise for alcoholics and chain smokers). Luckily most of the stuff from Aliexpress, Gearbest, etc... gets through, even though it usually takes aaaaages; usually my mail gets stuck for about two weeks in some sort of detention center ... What ???It sucks that there aren't more physical brick & mortar shops around (like in Japan or Singapore for example) in North America or Europe, where people could test out these products for fit and comfort as well as sound quality. The biggest problem is not being able to try out how they fit. This is the same reason why I still buy clothes and shoes in an actual store and not online...you cant buy stuff like this just based on specs and descriptions. Its gotta actually fit your unique shape.
