Lorspeaker
- Nov 29, 2010
sounds really good on my zs10 ..
That sure gave my ZS10's a little workout and they sounded fine
Good to know... but I doubt it is comparable to IT01 (even in stock configuration). But I`ll know better when I receive my ES4(teal, no-mic).Personally I don't think ES4 needs anything.
So let’s get back on track with discussing KZs.
If you could ask KZ to make your next dream audio product, what would it be?
If the mad scientists at KZ Acoustics are on their game they will issue this hybrid with their 6mm micro-dynamic for quick and textured bass coupled with their midrange BA for a vivid mid range (basically a more refined ZS3).
IMHO, this is one KZ that should remain warm and detailed. There are more than enough KZ hybrids with varying degrees of treble extension for micro-detail.
In short, a more refined EDR1 sound signature with bangin' bass, silky mids and very comfortable treble.
Isn't that the ZS4? Deleted wrong product in comment. new comment: when will these be released?.
I don't own the IT01Good to know... but I doubt it is comparable to IT01 (even in stock configuration). But I`ll know better when I receive my ES4(teal, no-mic).
Are the 500 the more appropriate for ZS6? How about sound quality with waxguard?
Isn't that the ZS4? I ordered 2 of them, and you are right about the signature. Really enjoyable.
How will you know which BA to block? ED16 has 2 different BAs (30095 and 50060).
Even if you block the BA that is causing your problem, there’s no guarantee that you’ll block the same BA in the other shell.
You could potentially block 1 50060 in the left, and the 30095 in the right. Or you could block both 50060s, when in reality it’s the 30095s that were causing you the problems.
You are so right my mistake, ES4's will edit.Unless you own a time machine, the ZS4 is not out yet.
Keep in mind that 98% of graphs you see are DIY graphs, are not compensated results, and are not taken on standardized measuring equipment.
I would contend that singular DIY graphs from a person we don't know are probably more reliable than subjective impressions from that same person, particularly when considering how unreliable our absolute hearing is and how easily colored it is by various biases.Keep in mind that 98% of graphs you see are DIY graphs, are not compensated results, and are not taken on standardized measuring equipment.
