DocHoliday
Wow those green shells look more enticing now. I was resisting buying a 2nd pair of ZS6s but...oh my...
They actually look even better up close and personal.
Thanks Pod, this is priceless information. That answers a ton of questions. Much appreciated! Good to know that the SS hasn't been ruined. For a little while I thought I'd have to stock up on the ZS6(i). It's good to know there is no change. Way to go KZ! If it ain't broken, don't fix it.
So, I liked the ZS6 so much, that I bought a second pair, here in comes my predicament, and sorry if this has been discussed, but too many pages, anyhow, they seem to sound quite different, the newer ones sounding more immediate, slightly warmer (less treble), using same cables and same tips...
Could class it as expectation bias, but I had none, additionally, the rear of the boxes are different...
Left is first pairs box, right is second... Question is, if there are different versions, which one is which (i.e. which is the newer production run), or if there isn't a newer version, is this a QC concern for new buyers)?
Through a mixture of inattention and carelessness I have 2 unopened black ZS6 from the initial big discount Gearbest offered the first time. That's in addition to the opened red and black pairs. So if it turns out that there really is a mk2 of them and someone feels a need to have an older pair I'll be happy to arrange a deal for whomever wants. Right now they're just sitting in their boxes since I have no reason to open them. Of course that's in addition to the ZS5 mk2 that's unopened sitting right there next to them since I already have 2 of those opened too. Actually they're sitting on the unopened BossHifi B3 since I ended up buying a duplicate of that too.… For a little while I thought I'd have to stock up on the ZS6(i). It's good to know there is no change. Way to go KZ! If it ain't broken, don't fix it.
So wait, the ZS6 hasn't been revised now? I thought people had decided KZ did revise it, since new marketing photos shows changes to the BA arrangement and configuration?
…Good to know that the SS hasn't been ruined. For a little while I thought I'd have to stock up on the ZS6(i). It's good to know there is no change. Way to go KZ! If it ain't broken, don't fix it.
Could the apparent increase in efficiency just be a subtly increased midrange due to a configuration change?So wait, the ZS6 hasn't been revised now? I thought people had decided KZ did revise it, since new marketing photos shows changes to the BA arrangement and configuration?
Good news, I thought I'd duplicated myself again when I got an ED9 and EDR2, think I got the model numbers right. They are practically identical in configuration, topology but they're obviously different sizes when compared. But I'd received them about a week apart from each other and it wasn't until I went to the burn-in pile to grab something to replace what I'd just finished with did I realize that they were different.
I like both as a small discreet for napping or sleeping IEM that sounds decent.
Be aware that those are .78mm and KZ uses .75mm.
I've not used .78mm on my KZ's yet, but you should still be aware of it. Besides, they look very similar to the TRN cables which are .75mm and cost less.
I have the black and the white. It's a good cable.
Hi doc,
Just received my white cable. After testing with ZS6, i made some observations..
1. The TRN cable seems to emphasise treble response significantly, hence creating a wider soundstage and micro detail retrieval is much more noticeable.
2. It slightly reduces bass impact, more obvious in the midbass region and slightly less in subbass.
3. It doesn't come with the guide wire so thats a plus.
The above are comparisons against the Ak Upgraded ZS5 Gold Plated Cable (image from fellow head-fier) which I've been using since i purchased my ZS6 about a month ago.
Where can i find the black colour?
Seems its sold out on Ali.
I'm also thinking of buying the TRN Silver cable when everyone on Aliexpress comes back from CNY vacation. The black is available from banned seller when I checked last night.
Hi doc,
The ZS6 has more impactful bass but it does seem to have more energy overall and looking at the specs on yhe boxes nothing is different but you can tell they have more bass right out the box.
Sent you a pm and you can ignore all thise links if you have something already just let me know.
Cheers
Here is crappy smartphone pic:To those who got silver "upgrade" cable with angled 2-pin for ZST/ZS3, white rings jack and have measured it having imbalance and high impedance, then, cut off that crappy jack and replace with better like Neutrik NTP3RC-B (though this is almost same price as cable) for example and You get around 0.5 Ohm impedance for R/L/G (multimeter leads resistance of 0.3Ohm already extracted), which is quite good and basically same as stock ZS5/ZS3 teal-color cable, just much more comfy and nicer looking. I also cut down 2-pin plastic "frame" around pins, so it fits my ZS5 like a glove.
Will post pic later.
