Thanks for the heads up. Any noticeable sound quality difference or just for comfort/fashion?
The white TRN cable is still in it's original packaging and thus far the black TRN cable has only been coupled to the TRN you see in the first image, but in general I purchase upgrade cables for quality, comfort, decreased microphonics and aesthetics.
Hakuzen tested several of the cables (for resistance) that were designed for use with KZ in-ears, but you'll have to ferret that out unless someone else re-posts it here again. Typically, your choice of eartips and your choice of source will have a greater effect on sound shaping than IEM cables. Usually, if changing cables makes a difference there is something else in the equation that is causing it and you'd have to do your due diligence to figure out what it is.
I ran into this with my ES3 a few pages back, but haven't had a chance to narrow it down yet.
The tri-braid upgrade cable made them a little brighter than the stock cables. I was literally surprised at the difference. They're warm and smooth with the stock cable, but with the tri-braids the mid-bass just seemed to drop and the upper midrange and lower treble moved forward. I've been used to the warmer presentation. Not sure if I like the brighter sound with the upgrades. I'll have to play with them for a few days.
Didn't expect this.
Anyone else have the ES3, tri-braided upgrade cable, stock cable and a DAP with less than 1.0 impedance?
If so, test while using a splitter and please use the track in the spoiler drop down to report your findings (if your DAP is android based you can access YouTube).
Thanks
Fiio X3(i)
Output impedance - 0.3 Ω(32Ω)
Output power - 540 mW (16 Ω/THD+N<1%)
KZ ES3
Impedance - 18 Ω (though it's been reported to have 10 Ω)
Frequency Response 7hz - 40khz
Sensitivity - 106db
*** EDIT ***
I forgot that I saved Hakuzen's info:
DC resistance of KZ cables (read by DMMs), in ohms (left, right, and ground).
zst/es3/zsr type (valid for zs3/5/6, sometimes plastic trimming suggested):
(31) kz plated (4cords,w/transp,black rings)......................0.35/36/40 0.35/37/39 0.35/37/40
(31)
(38) kz zst/es3(/zs5/zs6+trim) plated+metal plug+6cords...0.42/43/45/52/42/43 0.43/43/45/44/43/44 0.44/43/45/42/44/43
(38)
(06) kz es3 stock mic.........................................................0.66 0.66 0.66-68
(08) kz zsr stock mic..........................................................0.64 0.64 0.88
(32) kz plated (4cords,white rings,gearbest)................0.63/76 0.60/62 0.61/83
(02) kz zst stock mic..........................................................0.95 0.87 0.87
both types:
(34) zs3/zs6/zst/es3 colors(orange)...................................0.70 0.70 0.70
(35) zs3/zs6/zst/es3 colors(gray).......................................0.64 0.79 0.66
zs3/5/6 type:
(30) kz zs3/5/6 plated (4cords)..........................................0.67/70 0.67/70 0.67/70
(40) kz zs3/5/6 ofc plated (4cords,grey,"new",thick coat)...0.69 0.70 0.68
(40)
(07) kz zs6 stock................................................................0.70 0.60 0.39
(04) kz zs5 stock................................................................0.66 0.63 0.38
(00) kz zs3 stock mic..........................................................0.84 0.84 0.84
(35) Grey 2-pin with translucent connectors
(34) Orange 2-pin with translucent connectors
(42)
Sorry, I'll have to clarify this TRN cable's measurements.
