Pruikki
- Nov 30, 2012
yes please.Yes, they help but not so much. I've ordered spinfits. When they come I'll inform you about the outcome.
Open the nozzle, put a tiny drop of glue or something similar to block one of the BA. This helped but it is still sibilant. It might be enough for you. I find foam tips veil the sound a bit. Still enjoy my zs5 v1 more though.Got my kz zs6 for a month been running it for a while. However the treble is really too sharp for my liking compare to zs5. Anyone got the same issue any tips to modify it.
Has any one tested if the bluetooth cable actually supports AptX?
performed some tests on my phone and I believe it doesn't support it... maybe that is the reason why there is some audio lag in vids
So to make sure that I understand, they changed the circuitry to remove a feature? One that was pretty much specifically designed just for the purpose of their product? Reducing lag in wireless sound?The early versions of it are supposed to support it, it was dropped when they revised the circuitry.
Aptx isn't supposed to eliminate lag. That's Aptx-LL, which I've never seen the KZ Bluetooth cables advertised as having.Has any one tested if the bluetooth cable actually supports AptX?
My new cable still advertises aptx though
Just ordered the red ZS6 today. Is the treble really that unbearable compared to other "notorious" ear-piercing Chi-fi IEMs like the Seahf AWK-009? I also read on the aproear website that the soundstage isn't that spacious compared to the ZS5, and if it's true then I think I kinda regret buying them as I was hoping to get an even wider and deeper soundstage, similar to or better than my ED9.
Zs5 v1 has better soundstage than zs6.
