Smiped
- May 25, 2015
As far as I know, there are no other 0.72/0.75mm 2-pin BT modules.
But anything designed for 2pin 0.78mm plugs (Westone/UE compatible 2-pin BT cables, Auglamore has a nice neckband one, etc) will be able to connect with KZs, but have the same problems as any other 0.78mm pin cables with KZs (stretches them out too far to use stock cables).
Woah, those cables are pretty expensive compared to the stock KZ ones.
So the 2 pin 0.78mm can connect, but what do you mean it stretches them out too far?
