So I've had a need for a small earphone for sleeping, and one of the smallest IEMs I already own is the KZ HDS2.
They aren't in my listening rotation that often, because I've never really liked how they sounded. They were just too neutral and lacked bass, which just made them boring and narrow sounding. The nozzles are odd-sized and shaped, and not many tips fit other than the stock tips (goofy dual flange tips that are uncomfortable and don't seal well at all). I always felt like the tips had to be the cause of the gutless bass.
Well, I decided to play around with them and see if there were any improvements lurking inside.
The 1st thing I did was swap the rubbish stock tips for some other options. Foams sounded worse, robbing them of even more bass. The story was the same with wide bore tips (shouty trebe and no bass at all). Then I struck pay dirt. Using a small screwdriver, I was able to gently stretch some KZ Starlines on the massive tip. WOW, what a difference! These things were completely transformed. There's now
gobs of bass/sub-bass (when called upon - not overpowering). And thanks to the Starline tips, they're very comfy and stay in the ears with kung-fu grip. With the Starline tips, they sound like the u-shaped HDS3 (an excellent IEM).
Realize that the HDS2 are a TINY IEM. However, for sleeping they just barely stuck out of my ears just enough to rub when side sleeping. The trusty Dremel to the rescue - 5 minutes later and I had the rear section of the housing buzzed off. This made them short enough to completely disappear deep inside of the ear. They're sooo comfy when sleeping now.
After cutting the end off, the rear of the housing becomes "open" (exposing a small 1/8" hole in the rear of the housing). I used them like this for a few days, and I loved the much wider soundstage from the open back. But the open back also made the mids too forward, which just didn't sound right to me. So as a temporary measure, I took a hole punch, cut 2 pieces of vinyl graphics film I had laying around, and slapped them over the hole (in other words, fancy tape). The sound was back the way I liked it (ie the same as they were before I cut the housing down). I ordered some tiny 7mmx1mm neodymium magnets, which I'll epoxy onto the back in place of the vinyl as a permanent solution once they arrive. I'll be able to 'stick' them together when not in use (a popular feature now on IEMs, especially bluetooth IEMs).
Anyways, the bottom line is if you have this IEM and have never been happy with the sound, ditch the stock tips and get some KZ Starlines on there. You'll seriously love the way they sound. You'll have to be really patient to get them all of the way on the nozzles, but the results are well worth it. And if you're looking for some really nice sleeping IEMs (which is already a market with
extremely limited choices), consider trying the HDS2 (regardless of whether you cut the end off like I did or not).
Here's some photos of the modded vs stock HDS2 (click for larger views):
Stock HDS2 - look at how tiny these are!
Modded HDS2 - even SMALLER now!
Stock vs modded HDS2 - Side by side
Closeup of the temporary vinyl piece on the back (to be permanently replaced by 7mmx1mm magnet). Sorry, I didn't take a photo of the open hole.
