hakuzen
- Feb 9, 2016
Some burn-in time later I can now present the the not so astonishing results
The first measurement was done at approx. <1h playtime, the second one about 20-30h of burn-in later. Each channel was placed in the coupler and measured 4 individual times the reduce the effects of positioning. The final measurements are averages over all measurements and channels, so 8 individual measurements total.
"No burn-In" in green, "burn-in" in blue:
As can be seen the burn-in has changed nothing. Before commenting with something like "but there's less treble above 10 kHz!", take a look at this graph:
The above graph shows 4 individual measurements of the left earpiece after burn-in. As the earpiece was taken out and placed again before every measurement, small deviations in the FR occur because of a slightly different positioning. High frequencies are particularly sensitive to this effect. I can absolutely not ensure that the positioning before and after burn-in is the same, hence the small deviations are to be attributed to the positioning in the coupler rather than to burn-in. Mind that temperature and other environmental influences do affect measurements as well.
I gonna tag @Brooko, @castleofargh and @hakuzen here as I think you guys might enjoy some "burn-in" measurements
PS: THD measurements didn't change either.
thanks! results are like expected
in my record, i've only experienced slight differences with some iems for the first 10-20 minutes (but didn't measure them right out of the box and then, so even in these cases the cause could be fast brain burn-in) .
