hakuzen
- Feb 9, 2016
i've been checking my notes about nx1 hiss.Thanks a lot. Tbh an amp looks optimal, I was looking into prices as well. I'm honestly just gonna get a nx1 cuz it's very cheap and another sets of buds. But since u mentioned it hisses a lot, are there any better alternatives? I won't mind a slight bump in price, thanks as usual ^^. Also learning a lot from these graphs u and others are posting, man I just realized i got a lot to learn
check them at https://www.head-fi.org/threads/the...utorial-in-post-2.800208/page-6#post-12994430
"In low gain, the hiss is maximum (and clearly noticeable) at minimum volume, and goes lower when raising the volume (it is low at 3/4 volume, and it disappears at maximum volume).
In high gain, you get maximum hiss at minimum and maximum volume, less hiss at medium (12h) volume."
after measuring it, decided to only use low gain mode. in that mode, you'll probably set high volume, and hiss is minimum there.
i got the nx1a for longer battery autonomy. it's very affordable, and i think it would be suitable for zs5 and other low impedance.
i dunno about its power (limits of current regards of load) and distortion. i should measure it with zs5. will do it.
EDIT: nah, forget it. low current capable. higher distortion than desirable. not suitable for ZS5.
