arielext
You added it to your Vali band?Caps L and R are really easy to change. I had a problem with the leather band and they sent everything to me so that I can unscrew it and change it.
Sorry so late answering this. I own a HVAC company and it has been over 100F here in Denver….no time to breath even LOL. To be fair, I was unable to compare the Thekk and Rognir side by side. I, unfortunately, had an event happen which forced me to sell the Thekk 1 week before the Rognir arrived. They do have a similar sound for sure, sub bass is a bit better on the Rognir. It has the same fuller or thicker sound like the Thekk had vs the Wodan which was a little thinner to my ears. Both have excellent details which is amazing for how musical they sound. Nothing analytical here but you also miss nothing. I wouldn’t say that they sound exactly the same, but the sound signature is definitely similar. I wish I had both still.Hmmm.. interesting. Should I be getting the Thekk given that I already have the Rognir and I really like the sound?
Or the differences aren't worth it now. (Aside from, obviously, completing my collection).
What's your opinion?
Thanks a lot in advance.
I finally have mine perfectly “bent, ” really appreciate your work on these, they are extraordinary headphones.every head is different and i always recommend the pressure test while listening to music - gently push inward to see if you need to adjust tightness if it affects sound
Rognir is better than most every way sound wise. Everything sounds cleaner. The bass is more detailed. Soundstage isn't even close. And even though the Stellia has the beryllium drivers, it just doesn't sound as crisp and clean as the Rognir. Because of the thin pads I would say that the Stellia is definitely more comfortable though. I have the heaviest version of the Rognir (bubinga) and weight is not a problem but it definitely is heavier on the head than the Stellia.Can someone compare the Kennerton Rognir with the Focal Stellia?
Sound quality (frequency response, dynamics, stage, etc.) comfort, size of ear pads (ears' space against the pads/drivers)
I sold my Stellia and replaced it with Denon D9200, and when I heard D9200 (especially its clarity) I felt bad having spent that money on Stellia. As I understand Rögnir is closer to D9200 with a better non-U (yet still crispy and extended treble) tonality, larger stage and better technicalities. Would you say it is like a thicker closed D8000?Rognir is better than most every way sound wise. Everything sounds cleaner. The bass is more detailed. Soundstage isn't even close. And even though the Stellia has the beryllium drivers, it just doesn't sound as crisp and clean as the Rognir. Because of the thin pads I would say that the Stellia is definitely more comfortable though. I have the heaviest version of the Rognir (bubinga) and weight is not a problem but it definitely is heavier on the head than the Stellia.
Unfortunately I've never heard the D8000. It is on my want to listI sold my Stellia and replaced it with Denon D9200, and when I heard D9200 (especially its clarity) I felt bad having spent that money on Stellia. As I understand Rögnir is closer to D9200 with a better non-U (yet still crispy and extended treble) tonality, larger stage and better technicalities. Would you say it is like a thicker closed D8000?
How is the treble compared to HEKse?Unfortunately I've never heard the D8000. It is on my want to list
To me it is a bit better. The Rognir sounds a bit more dynamic to me. Probably because the Stage isn’t as big which can make the sound a bit softer to my ears. I really enjoy it. No harsh or sibilance to my ears. It really is a delight to listen to.How is the treble compared to HEKse?
