Duggeh
Indeed
- May 9, 2005
I will hopefully get chance to hear the HD800 and a JH13 PRO in the next month or so. Of course, swapping out a K1K for an HD800 would be an even bigger task because I havent even owned a dynamic headphone amp in years.
I have been tempted to recable the K1K, but I think it pointles doing so prior to more sufficient amplification. I also doubt that any amp would flesh out the low end so that its more like the TakeT or the O2, although It might get close to or better than my modified AMT.
Originally Posted by robm321 /img/forum/go_quote.gif Duggeh, the K-1000s definitely need to be amped right to really hear what they are capable of just like the 007. When I first bought them. I tried them with several amps (some pricey ones also) and had you're same opinion of them. I loved them, but they didn't seem all that special. Even my KT88 tube amp in triode mode didn't put them over the top. And it should have been the perfect match looking at the specs and opinions around here. The F1 controls the drivers perfectly, but IMHO sound very analytical compared to the Aleph 3 which I prefer. If I decide to spend multiple thousands on an amp in the future, I would go to a 300b amp most likely. Didn't you have the aleph j or something? Anyway, I simply think you enjoy stats and the like, so why poor money into the K-1000? It improves with recabling in a significant way. ICs, power cables, power conditioners, source and recording all come through good or bad and like the HE-90, 007, etc really need synergy to make them shine. I just think dialing in the K-1000s and also dialing in the 007 and your others is quite a task, and I think with your preference you'd be better served pouring the money from the sale of your K-1000 into your stat rig. |
