cfc7
Interesting...thanks!Well, the XBA-N3 was actually the one IEM I was seriously considering buying when I went to e-earphones the day before leaving Japan, so I gave it a good listen.
I did compare it more to the EX800 though, since they have more in common and I was wondering if it would be worth having both. All that said I have to go by memory
From my memory the main difference between the N3 and the EX800 was mids and treble, which sounded smoother on the N3, you could hear the BA detail, refinement and texture, and I liked it a lot, actually preferred it over the EX800 but not by much. The EX800 mids can be a tiny bit hard and the treble can be too hot at times. Bass was relatively similar in quantity on the N3 and EX800, don’t remember much about the quality.
The FD02 (modded) is a little brighter than both the EX800 and the N3, but in modded form by no means bright. It still has very good bass quantity and quality, balanced. The thing that stands out is that I feel it combines the resolution, detail and refinement of BA with the dynamics of a DD. It’s extended, detailed, energetic, yet just smooth enough to never sound harsh (if it’s not in the recording....)
A track I used a lot for comparison is Stravinsky’s “Firebird” as it covers a wide range of frequencies and instruments, has some really difficult violin passages and it is a real challenge to convey the speed and energy of the piece.
https://tidal.com/track/77607310
I don’t know all the names of the instruments in english, but the FD02 is doing an excellent job at reproducing each and every one of them, with speed, attack, the right timbre and just the right amount of bite in the treble, sharp, but pleasantly so, not painfully. And the bass slams fast and hard, it’s really energetic.
I liked the N3 and if I had to pick between it and the EX800 I might have taken the N3 (despite Crinacle ranking the Ex800 much higher)
But if the choice is between FD02 and N3, without a doubt I’d pick the JVC.
Hope that helps a little...
I have the N3 and I'm using it and like it more and more in balanced mode.
My feeling about FD02 was that it could be too bright and fatiguing, with potentially aggressive highs but that's just from what I've read.
