chuck94022
- Aug 29, 2005
So far I am very happy with this unit. It is performing exactly as expected. I only have one real complaint. I don't understand why the gain controls need to be buried inside the unit. If it wouldn't adversely affect the sound, I would be happier with a control carried out to the front or back of the device.
As it stands, you must turn the unit over and stick something inside, a pretty far reach, to flip the four switches to the appropriate setting. It is not easy to begin with, and further, you could damage the board if you are not careful and choose the wrong sort of tool to reach the switches. In addition, since the switches are accessed from the bottom, you have to turn the unit over, which is actually not really advisable with those delicate tubes sticking out the top. So all in all it is an awkward operation. Since it is likely that users will use a high impedance set of phones with it, I'm surprised it is shipped with the switches set for low impedance. (Well, I guess this makes sense from a "could cause damage" standpoint. The low impedance setting will send out the least energy.) But it pretty much guarantees that if you are using it with a high quality set of cans you are going to be flipping switches when you receive it.
If you are using it with a low impedance set of ear buds I'm not sure why you bought it anyway...
But man, those hassles aside, it sounds great, and is improving with every hour of burn in.
